    Dec 2005
    anyone have any problems backing up the movie dejavu? i used ripit4me 1701 and dvd decrypter3540 to rip full disc and dvd rebuilder pro1204 to get main movie to fit disc after movie was burned i had a movie that was 2hrs 43 min long and i have clips of the extras tied in with the main movie with the movie sound track in the background.
    have you tried LATEST dvdfab decrypter?
  3. Member steveryan's Avatar
    Jan 2003
    Manchester
    Do a forum search for "Deja", a few people have had problems with it.
    He's a liar and a murderer, and I say that with all due respect.
  4. The extras feature "Surveillance Window" is interleaved with the movie. It plays like director's comment, except you see a "making of" for some scenes. If you play the movie in powerdvd and lookup the info, you'll see the movie is actually 1:58 long not 2:43. When you rip for the main movie you should see both listed...
  5. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Also check out the comments for/from the makers of AnyDVD....it mentions Deja Vu by name.
    Nov 2004
    Las Vegas
    mike487,
    Take a look at this post by peggypwr1. You selected Title 02 when you should have selected Title 01. You'll have to repeat the dvd rebuilder step again, making sure to keep Title 01, not Title 02.
  7. Banned
    Feb 2007
    Ecuador
    hi to everyone
    i just downloaded this movie from mininova the name of the file is deja vu dvd (fra eng spa), so heres my question how can i burn these movie in order to have all these language options when i play it on any dvd player
    Regards
    You are in breach of the forum rules and are being issued with a formal warning. Bye.
    / Moderator Baldrick
    Dec 2005
    Thanx eneryone used dvdfab and got it to work i guess rebuilder got the biggest set of vts files that were together and thought it was the main movie I thought the movie at 2 hr 43 min was a little long but then though maybe it was a type o on the jacket cover wich i have seen before on another movie.vegasbud was right rebuilder chose track 2 instead of 1 and after i got main movie didnt even use rebuilder done it with shrink because compression was 97%.
