You can add your touched-up still back using VobBlanker (freeware). Muxman (free) required.
RegardsLes -
To elaborate a bit on what blutach said (Hi Les!), read The Easy Way part at the bottom of my Menu Editing guide:
https://forum.videohelp.com/topic313743.html#1606732 -
In DVDRemake Pro you can edit background by exporting a frame (for both still/motion menu types; right-click on desired bg frame => export frame). Then edit/save as 24-bit bmp in Photoshop, encode with Muxman, import the result to DVDRemake as second project, right-click on menu bg in original movie => replace with still => select your new picture. If there was any audio stream in menu page, it will remain untouched with original length.
Nice guide Tom! Did you complete your PAL-NTSC guide mate?
RegardsLes
DVD Menu - Picture for navigation...
By nharikrishna in forum Authoring (DVD)Replies: 13Last Post: 23rd Mar 2011, 08:38 -
Edit DVD and keep menu
By Batmeat in forum Authoring (DVD)Replies: 6Last Post: 8th Mar 2011, 23:51 -
Edit dvd menu button
By canaQ in forum Authoring (DVD)Replies: 8Last Post: 24th Feb 2010, 08:13 -
How to edit a picture on a DVD?
By mhumble in forum Newbie / General discussionsReplies: 2Last Post: 8th Nov 2009, 01:53 -
How can I edit a montion menu of DVD?
By schtroumpfs in forum Authoring (DVD)Replies: 3Last Post: 9th May 2009, 06:57
