Hey guys,
first of all, this forum REALLY helps a lot.
Second of all, I wanted to ask you what is the standard configuation (mainly Video Size, BitRate, FrameRate, audio, etc.) when I am converting VOBs to Dv that I want to edit with iMovie HD.
Any other configuration items that I need to make sure are alright to match the iMovie video?
I forgot to mention that I am mixing footage from a DVD (VOBs) with footage of my own camera that I important straight to iMovie. Videos of the same even shot by different people. One of the people actually recorded their part straight on a DVD, no miniDV tape like I did.
Thanks guys!
In the Summary tab, under Target format, you may select the Quick Presets (
). When selecting the DV preset, all paramaters are set for compliancy.
Thanks for the reply.
On 1 of the VOB the size was 16:9 when I chose to: DV format(can't remember right now, I'm not on the same computer), on hte otehr VOB it said 3:2 or something... even though they were from the same DVD movie (from the same DVD I had 3 VOBs).
I'll go back to my friends house (where I was using FFmpegX and get teh correct info.. but there is somethign wrong there...
DVD VOBs and DV files are either 16:9 or 4:3, no other options there. If you know the set aspect ration to be wrong, then you can change it.Originally Posted by enzofsilva
A DVD can have both 16:9 title sets (e.g. a main feature) and 4:3 title sets (e.g. extras). But VOBs from the same title set should have the same aspect ratio.Originally Posted by enzofsilva
I think iMovie wants all video on a given project to have a single aspect ratio, tho', so if you really have a mix of 16:9 and 4:3 content (i.e. it's not a software error) then you may need to pillarbox the 4:3 content.
From Vegas to iMovie - Does the version of iMovie matter?
By and in forum EditingReplies: 4Last Post: 11th Dec 2011, 21:05 -
MKV2AVI best configuration
By katalogas in forum Video ConversionReplies: 0Last Post: 15th Jun 2010, 06:38 -
Newbie needs help - wmv to DVD and iMovie
By Jeff555 in forum MacReplies: 7Last Post: 16th Mar 2009, 16:27 -
Hard drive configuration
By ProducerHarley in forum ComputerReplies: 2Last Post: 22nd Nov 2008, 22:51 -
Receiving OTA DTV with Standar antenna and ATI AIW 9200. Possible?
By Gknight in forum DVB / IPTVReplies: 6Last Post: 19th Nov 2007, 19:41
