I've just made what I think is a major whoopsie - I haven't used SVCD2DVD to add separate VTS's for a long time and I've just done a full season of 'Shark,' putting four episodes on each DVD, one per VTS. The only problem is that I forgot to click the 'link' button, and just added the episode name in the 'button text' by mistake.
Are all these folders on my drive with the full series in them now for the bin??![]()
"Never do today what you can put off until tomorrow..."
If I understand you right, the project should be fine. Did your menu layout show named buttons? If so, I think you're good to go. Play the project output in your software DVD player if you have any doubts.
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
Yes, the menus show the named buttons, and I just played the content of a few of the folders with VLC and the episodes appear to be linked to the buttons... I suppose I'd better sit and check every single one just to make sure though!
Thanks"Never do today what you can put off until tomorrow..." -
I wouldn't worry about it. I never use the "link" button and mine are all fine. Each VTS automatically gets its own button.
Just looked it up - all the link button does is sync the text between the "Name" and "Menu Button" boxes.Dwight
- Herm Albright
add Disable automatic tool link to quick reply?
By lordsmurf in forum FeedbackReplies: 0Last Post: 12th Apr 2010, 10:51 -
How to add subtitles link to "update ifos" doesn't work
By sinuhemoises in forum Newbie / General discussionsReplies: 1Last Post: 3rd Apr 2010, 15:35 -
How do I add an fmt=18 link that opens in the original tab or window
By waigy in forum Video Streaming DownloadingReplies: 5Last Post: 1st Jul 2008, 04:22 -
Sorry, I forgot, how to use VDUB flags
By vodmare in forum DVD RippingReplies: 3Last Post: 7th Aug 2007, 11:44 -
Such thing as dual link to single link DVI-D cable?
By Mizkreant in forum DVB / IPTVReplies: 1Last Post: 14th Jul 2007, 06:51
