    Mar 2007
    I am trying to convert but I get cutouts in the picture and no sound
    FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
    Wed May 23 15:44:07 BST 2007
    Mac OSX universal build for ffmpegX
    libavutil version: 49.0.0
    libavcodec version: 51.9.0
    libavformat version: 50.4.0
    Seems that stream 1 comes from film source: 150.00 (6000/40) -> 30.00 (30/1)
    Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Users/sfx/Desktop/Dubai_final.mov':
    Duration: 00:01:00.4, start: 0.000000, bitrate: 1858 kb/s
    Stream #0.0(eng): Audio: aac, 44100 Hz, stereo
    Stream #0.1(eng), 30.00 fps(r): Video: rpza, rgb555, 320x240
    Codec type mismatch for mapping #0.0 -> #0.0
    can you please help?
    THANX!!!
    Moving you to our ffmpegx forum section.
  3. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    Originally Posted by grooveguru
    Input #0, mov:
    When using the ffmpeg engine and your audio/video streams appear inverted (audio before video), then enable "Invert mapping" in the audio tab.
    Video: rpza, rgb555
    Rare codec, you don't see that too often. It seems well supported, tho'.
    Mar 2007
    I did enable invert and this happens:
    Encoding started on Thu May 24 13:02:42 BST 2007
    hm...
    please help?
  5. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    Weird, invert mapping should not result in mapping #0.0 -> #0.0,
    but should give mapping #0.0 -> #0.1 and/or #0.1 -> #0.0.
    If you have QuickTime Pro, then you could extract the soundtrack (Cmd-J, then Extract button), delete the soundtrack from the movie, select all and copy in the extracted soundtrack clip, and add the soundtrack back (Edit>Add to Movie), then save as a new self-contained movie. This will reverse the stream order, and ffmpegX should not complain about the mapping anymore.
