A friend gave me his Quicktime video to work on (.mov files), but Final Cut won't accept the data. It says "unsupported frame rate" . Also, I noticed that the pixels are 640 x 480. How can i fix this? Thanks.
what is the frame rate of the video?
Check it by opening it in Quicktime and
performing a (apple-i) Info command.
If it says 25fps for example, that is PAL.
you'll need to verify what your settings are in FCP.
By default, they are set for NTSC.
If you want to import PAL -framed video, you'll need to
switch the defaults to import the video, or
re-"hijack" it ( transcode it) to NTSC framerate in QT Pro
for ingestion into FCP."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
Actually it is in MPEG4 format, not MOV.
I opened it but it does not tell me the frame rate.
Just the size: 640 x 480
Codecs: Mpeg-4 video, AAC -
aah....FCP will not accept Mpeg-4 muxed streams.
The data stream it accepts are DV (NTSC or PaL, Raw),
Quicktime .MOV, and depending upon the codec not
being a muxed codec ( any flavor of MPEG) some .avi
files (FCP 5 or later).
You'll need to get a copy of MpegStreamclip, and open the file,
and save it out as a DV Stream ( Demux/Remux).
The DV stream filve will then be importable into FCP."Everyone has to learn, so that they can one day teach."
Urban Mac User
Final Cut X
By Tom in HD in forum MacReplies: 1Last Post: 29th Oct 2011, 10:35 -
final cut express 4 - capture issue
By devdev in forum MacReplies: 2Last Post: 30th Aug 2011, 15:23 -
Vegas or Final Cut?
By Nuke Shower in forum EditingReplies: 6Last Post: 29th Jul 2008, 20:37 -
Just Got Final Cut Pro 6
By The Monkees in forum MacReplies: 3Last Post: 14th Nov 2007, 14:24 -
final cut express and final cut pro 6
By ednarophati in forum MacReplies: 1Last Post: 16th Jul 2007, 11:05
