I've got an XVid file, that I want to burn to DVD.
I used ConvertXtoDVD to convert it to VOB files, then VOB2MPG to convert it to an MPG. However, on attempting to burn this MPG, the audio was about 5 seconds behind the video (at one particular point, I'm not sure if it increases or decreases). The audio was fine on the original AVI.
On opening the MPG with VdubMod, there is no audio at all. The same happens when I open it in screenblast Movie Studio, which is the software I use to edit video.
How can I fix this problem?
Results 1 to 21 of 21
Audio is present when playing CXTDVD's VOB files, though it is out of sync.
Your process seems rather convoluted - Why convert to Video DVD first, then back up to mpg again?
/Mats -
convert directly from the xvid to mpg with something else then like tmpgenc xpress.
I use that convoluted process, because I prefer that to having a lighter wallet.
Convertx2dvd isn't free. And for about the same money, you'd be able to buy a DVD player with AVI playback capabilities - no need to convert at all.
There are many free roads going from AVI to mpg. Take a look at the plethora of guides at your disposal if you select AVI to DVD under CONVERT left.
I'd suggest avisynth + HCEnc - both good & 100% free.
/Mats -
I've tried TMPGEnd, which gives me an m2v file that has to be muxed or whatever anyway, so it's not much shorter.
And the audio is now cutting out somewhere between 15 and 20 minutes in. -
I don't really care what you prefer, I want to get this burnt in the way that I do all my DVDs.
That said, what's going on with this audio? -
I don't really care what you want, but for proper DVD's you are using wrong tools.
1. GSpot for analysing the source
2. VirtualDubMod for fixing the things that are not suitable for conversion based on analysis from GSpot and for separation of video and audio streams.
3. bitrate calculator for finding appropriate average bitrate
4. FitCD, Avisynth and HC for conversion of the video
5. ffmpeg for conversion of the audio
6. GuiforDVDAuthor with Muxman multiplexing for authoring and menu creation.
7. ImgBurn for burning. -
VDubMod refuses to do anything with the file, citing various error codes.
Whenever I convert it to VOB, MPG, or anything else, the audio ends up out of sync.
The exception to this being when using TMPGEnc, as the audio just cuts out 15-20 minutes in (this doesn't happen on any of the others) in the muxed VOB files.
It seems there's something at that point in the video that's causing the audio to either vanish, or go out of sync. -
I know the answer to your problem, but you were too rude to the others who wanted to help you. Best of luck.
I must have missed the "being rude" part.
GSpot:
0x0055 MPEG-2 Layer 3 CBR audio, 16000Hz 40 kb/s tot , Joint Stereo, Codec(s) Installed -
The clue is in these sentences. No doubt, the source file has errors, preventing successful conversion to other formats.Originally Posted by koberulz
/Mats
MiniDV Video & Audio Problem - Corrupted, Detiriorated, Missing Audio
By 4truce in forum Capturing and VCRReplies: 14Last Post: 4th Aug 2011, 07:36 -
additional audio decoder needed to play this soundtrack-Dolby AC3 Audio
By tbone1209 in forum AudioReplies: 6Last Post: 19th Jun 2011, 21:58 -
removing the commentary audio track from an AVI file with mpeg layer3 audio
By wildrthanevr in forum AudioReplies: 1Last Post: 10th Mar 2009, 02:29 -
Easy DVD to MP4/MKV with Dual Audio, 'soft' Subtitles, and 5.1 Audio?
By Grovest in forum DVD RippingReplies: 4Last Post: 3rd Nov 2008, 05:12 -
Sticky labels can screwup the playback of your DVDR's
By Craig Tucker in forum MediaReplies: 556Last Post: 11th Sep 2008, 04:13
