Hello,
I am having trouble finding a free program to convert my xvid to svcd
I have tried avi2dvd but it keeps giving me an error...
Does anyone know of any other free programs out there which can do this?
Also, how do i burn a svcd? do i just use the standard settings? joliet etc..
ok i just tried thefilm machine but when i preview the image is squashed sideways. When i put this on the dvd player and play it on tv would it go back to normal?
Also, the avi video i have is taken from a HD tv and so it has those black borders on both sides of the video, how can i fix this? can i? -
It might look squashed because the svcd frame size/resolution is 480x480/576 but the Display Aspect Ratio is 4:3 so it will be resized when you use a real dvd player or software dvd/svcd player.
ok i just looked the avi is
608x336 (16/9)
And i just found out something...
When i preview with both 16:9 and 4:3 the video still is squashed but when i play in media player its normal.
I think it's because of the black borders it has? How can i get rid of them? -
ok i got something here...
I did a search on these forums and found out
Some films are shot in ratios of 16:9 (which this video has) and some 4:3
So this is the question, the big movie tv's are 16:9 and the normal tv's are 4:3 am i correct?
So in thefilmmachine i put in to add borders, 4:3 ratio and not have it do the ntsc to pal and it works out alright! except there are borders on all 4 sides now.
So...
What is difference between ntsc and pal? what do normal tv's run on?
If i put this on a cd and run on my player would the border still be there? or would the video be big enough that the borders would not be seen on screen?
burn in a subtitle in Xvid without re-encode
By Cazz in forum SubtitleReplies: 6Last Post: 3rd Sep 2011, 00:28 -
Simple Xvid vid will not burn, why?
By capman21 in forum Newbie / General discussionsReplies: 10Last Post: 9th Aug 2008, 21:44 -
Best Way to Burn HD Xvid files to DVD?
By expat in forum Newbie / General discussionsReplies: 5Last Post: 28th Sep 2007, 11:51 -
Burn Software with Menu & burn xvid avi
By CynthiaBlue in forum Newbie / General discussionsReplies: 3Last Post: 4th Jul 2007, 21:46 -
IngBurn can't burn xvid
By crowheart in forum Newbie / General discussionsReplies: 2Last Post: 16th May 2007, 16:27
