I uninstalled a trial version of NOD32 antivirus as the only change to my system today and at first I noticed the internal beep PC speaker making noises but didnt think much of it until I tried to play an mp3 and WMP said it cant play it becasue there is a problem with my audio device.
I then tried it in VLC media player and it is just silent.
Then I noticed nothing at all would work with sound! So i ventured into control panel and under sound/audio devices it says there is none installed.......how do I reinstall my audio device which is built into my motherboard???
I then checked device manager and I have found something in that may be the problem.....I dont know what the microsoft kernal system audio is but it apparently has a problem.
My AC97 though it says is working fine which I dont understand.
so here is some screenshots that may assist in the problem solving:
anyone know whats going on?
Thanks in advance for any help.
P4 2.6ghz
Realtek AC97 onboard soundcard
gforce 5200 graphics card
1gig ram
80gb hdd
	All you should need to do is reinstall your MB drivers. You will need to determine the MB model and/or chipset. Then just download and install the latest version. The MB typically has a name and/or model number marked on the PCB or with a sticker. Google is your Friend
	Make sure that the WINDOWS AUDIO service has been started.
 CONTROL PANEL > ADMINISTRATIVE TOOLS > SERVICES
 Probably on exit, the AV program stopped (or disabled) this service.ICBM target coordinates:
 26° 14' 10.16"N -- 80° 16' 0.91"W
	You could even go into the device manager and remove it, then select scan for hardware changes. This will redetect the audio and prompt for the driver. Believing yourself to be secure only takes one cracker to dispel your belief.
	I will try Dv8teds way first and see how I go, then I will search for new drivers as Krispy Kritter suggested.
 SLK001, I had a look but it was still enabled.
 Can anyone tell me if Microsfot Kernel is likely to be the problem? I dont know what it is but thought my onboard sound was the AC97 realtek thing which it says is fine?
 Thank again for all your help.
  each audio track on different audio channel or deviceBy mikedepetris in forum Software PlayingReplies: 2Last Post: 28th Nov 2009, 09:56
  HD Pvr 1212 - device is not connected - can't use device in arcsoft softwarBy yoda313 in forum Capturing and VCRReplies: 9Last Post: 16th Aug 2009, 18:22
  Default Audio Device in VLCBy EliteMarine in forum AudioReplies: 3Last Post: 14th Jan 2008, 21:44
  Conflict with Audio DeviceBy kerrex_2006 in forum AudioReplies: 1Last Post: 23rd Jul 2007, 16:40
  win xp audio deviceBy dvds2u in forum ComputerReplies: 8Last Post: 15th May 2007, 16:03
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
