Hi guys,
I have recently purchased a hard drive media player from ebay to store my vids on and watch them directly on my tv. The one I have bought is listed here:
http://cgi.ebay.co.uk/Portable-3-5-500gb-Media-Centre-DivX-Hard-Drive-Player_W0QQitemZ...QQcmdZViewItem
The reason for my post is that, whilst most of my video files play fine, i get the following error on others "CODEC NOT SUPPORTED (QPEL)".
Now, these all play fine on my PC and they are xvid files but a search for QPEL showed me that it is a slightly different compression, is this correct?
If so, I would be greatful if anyone knew how to get these files playing on this media player (via maybe new firmware or something which may exist that i cant find?) or failing that, is there a way to convert the QPEL files to something umm, non-QPEL?? (lol, i'm new to this so i hope that makes sense!)
I really appreciate any help guys.
You may have to re-encode them, AVI ReComp is probably the easiest way to do that. It will re-encode your AVI's to "standalone friendly" files.
With a 3.6ghz CPU, that shouldn't take too long.
cheers, thats awesome, i will try
VirtualDub/Xvid question: YV12 vs. XVID FourCC in the xvidvfw.dll driver???
By KneeRow in forum Video ConversionReplies: 14Last Post: 1st Aug 2010, 14:35 -
How to reconvert an AVI with AutoGK, remove QPEL, GMC etc
By Baldrick in forum User guidesReplies: 35Last Post: 10th Jan 2010, 23:00 -
Philips DV624/37 AVI (XviD) Problems (Not QPEL/GMC)-could it be the codec?
By wingalls in forum Newbie / General discussionsReplies: 4Last Post: 2nd Nov 2008, 01:13 -
Weird I don't have XviD or DivX codec installed but I can see Xvid movies
By Talayero in forum Software PlayingReplies: 4Last Post: 5th Jun 2008, 12:47 -
XviD: Qpel, GMC, Max consecutive B-VOPs, and N-VOP ??
By GangstaRap in forum Video ConversionReplies: 17Last Post: 20th May 2007, 04:59
