I've been using IMTOO DVD Ripper Platinum (using the WMV2 codec) on Windows XP to create .AVI files. It has worked well for my last three projects: 27-minute DVD, 42-minute DVD, and 15-minute DVD respectively.
However, my last video project involved producing a 2 hour and 15 minute video (burning this DVD at a different speed than the previous three projects because of the huge time increase to over 2 hours).
This may be a cause for the problem-maybe not...the problem being that when my ripper software registers this DVD, it automatically compresses the preview (and the image) horizontally: a black margin on the right and left side of the now distorted image. Is there anything I can do to rectify this? Does this ripper have a limit on video time to be ripped? Should I try to rip separate chapters? Is there another inexpesive/free ripper that's better?
In addition, as part of the process, I create separate .FLV files from the .AVI file using the ON2 FLixPro encoder. This usually takes two or three hours, but I tried it on a five-minute section of this large video, and after NINE hours, it was only 20% complete! Could this extensive time be related to the compressed file/forced codec?
Any and all advice would be appreciated.
Thanks!
Results 1 to 1 of 1
Compression codecs lost! Where do they come from anyway?
By Artas1984 in forum Video ConversionReplies: 4Last Post: 22nd Apr 2013, 00:52 -
VirtualDub Compression Codecs All missing?
By blazr in forum Newbie / General discussionsReplies: 0Last Post: 29th Feb 2012, 05:14 -
Best compression program/format/codecs without losing quality
By adrian2055 in forum Video ConversionReplies: 12Last Post: 20th Jan 2011, 15:29 -
So many Video Codecs to comprehend; best Video compression?
By bulava in forum Video ConversionReplies: 7Last Post: 3rd Mar 2009, 15:01 -
Help D; Codec Sniper Entries/Registering Codecs/Broken Codecs
By Antischism in forum ComputerReplies: 0Last Post: 5th Nov 2008, 14:29
