I was wondering if there was a tool that converts Xvid (or any other format) to the KVCD format?
				Results 1 to 9 of 9
	KVCD isn't a format, it's just some MPEG codec settings to make a 'out of specification' VCD that may or may not play on a set top player. TMPGEnc encoder can do it, as can many encoders that allow the settings changes. Do a Google search for 'kvcd tmpgenc templates'.
	You want to downgrade the quality? Want my help? Ask here! (not via PM!)
	My experiance with kvcd disk are that it is a very crappy way to record a movie. I have never seen one that was any good.
	I agree, better off watching the avi on the PC than burning a K vCD disc, you are loosing bitrate and resolution.. better off to convert to DVD,
 yeah DVD discs cost more the file size goes up, but you won't loose any quailty if you do it correctly
 for standalone use and watching on the old teley, DVD is much better than K vCD,
	And also for *nix systems, there's K V C D 4 N I XOriginally Posted by Abond
 http://kvcd4nix.sourceforge.net/screenshots.html
 Which is an approved package in FreeBSD's ports collection!
 http://www.freebsdsoftware.org/multimedia/mkxvcd.html
	I don't recall anybody asking about Linux software.Originally Posted by rds_correia
 All 32 of your posts are about Kwag's crap "formats". Want my help? Ask here! (not via PM!) Want my help? Ask here! (not via PM!)
	I don't recall anyone asking you about opinions either!Originally Posted by lordsmurf
 The question was about a conversion tool, so your way off topic.What's someone elses crap, is someone elses treasureAll 32 of your posts are about Kwag's crap "formats".
 [Learn to do KVCD's the right way, and then you just *might* learn something about advanced video encodings]
 Oh, btw I forgot to mention, we at kvcd.net don't really do KVCD's anymore!
 It's all KDVDs with HC encoder, Phil's new tool for prediction, and kwag's tools which are now open source, if you weren't aware of that.
 Here's a little screenshot of Phil's tool, so you can all see what we are talking about:
 @mjaeson,
 To add to your question, there's also a commercial encoder, YMPEG, http://www.ympeg.com that supports KVCD/KDVD natively.
 And for MACs, there's ffmpegX, which also supports KVCD/KDVD built-in.
 http://homepage.mac.com/major4/
 And MythTV, http://www.mythtv.org also has a plugin (nuv2disk) that let's you transcode your captured AVIs directly to KVCD/KDVD!!
 Check it out here: http://www.mythtvtalk.com/nuv2disc/screens/index.html
 Cheers!
  KvCD to vobBy natty in forum Newbie / General discussionsReplies: 2Last Post: 19th Aug 2010, 16:37
  MPG to KVCD HELPBy G33333 in forum Video ConversionReplies: 12Last Post: 25th Dec 2007, 07:00
  KVCDBy Bat21UK in forum Authoring (DVD)Replies: 7Last Post: 22nd Dec 2007, 16:31
  2 hours plus on one kvcd - how?By t41 in forum Newbie / General discussionsReplies: 1Last Post: 16th Sep 2007, 12:08
  KVCD to DVDBy buttzilla in forum Video ConversionReplies: 2Last Post: 6th May 2007, 09:01
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
