Hello, first let'me say that this forum is the best ever, everytime i had a question...the answer was ... Check Video Help Forum...
Anyway What I want know is what is the best program to creat DVD Menus????![]()
Photoshop for images
3D modeling program for any 3D
effects software like After Effects for any special effect
and your favorite NLE for video editing (Adobe Premiere, Final Cut Pro, Sony Vegas)Want my help? Ask here! (not via PM!)
I would be inclined to DVD Lab Pro. It will let you create menu by importing picture or motion into it with sound. It has a good selection of button types and if you want to get more fancy than there is a DVD Menu Studio from the same Mediachance group.
If you want just menu on its own than Menu Studio will do the trick. -
The gimp for images and animation (gap)
Blender for 3d animation
Wax 2 for effects similar to windows movie maker
Avisynth , scripting
Wings3d for simple 3d model creation
Basic menu build via dvdauthorgui , just include a small title with audio so as to allow menu generation .
Load your real dvds title via pgcedit , and simply click on title , select "import menu' .
Fetch your menu (copy) , from dvdauthorgui's output folder , patch nav commands to suit , save .
Play back prior to burning to disc .
How to creat a banner behind the subtitles?
By microlab1986 in forum SubtitleReplies: 4Last Post: 20th Jan 2010, 06:22 -
Creat DVD with VOB files, without re-encode
By temp759 in forum Authoring (DVD)Replies: 8Last Post: 17th Apr 2009, 09:01 -
creat dvd to fit your tv screen
By projecttemp in forum Video ConversionReplies: 2Last Post: 16th Jul 2008, 07:37 -
How do I join JPG images to creat an AVI file
By forensic in forum EditingReplies: 9Last Post: 15th Mar 2008, 21:23 -
HOw do you creat e-com website?
By snickdog in forum Off topicReplies: 5Last Post: 3rd Dec 2007, 20:33
