hello
can you tell me please what hardware to buy to watch TV on my laptop? whats the best?
I also want to hear FM radio and record both radio and tv and to see teletext too
thanks
Since you are from Hellas your best bet is to start looking at reviews for a USB DVT-B TV Tuner. Depending on the signal strength in your particular area, you may find the portable antenna that comes with these "TV's" will not be enough to get a decent signal. If plugging your laptop into into an aerial wall socket is ok, you should be fine.
You need to get one that has a BDA driver that will support a wide range of software - some don't. Also, a large number of TV tuners cannot pick up FM radio, but can pick up digital radio. What sort of laptop? -
the laptop is T2030 1.6GHz with 1GB RAM
is this good?
http://global.msi.com.tw/index.php?func=proddesc&prod_no=74&maincat_no=124&cat2_no=129
Mpeg-4 stutter freeze on laptop 1, laptop 2 plays fine- why?
By sevenofone in forum Software PlayingReplies: 1Last Post: 8th Apr 2011, 17:15 -
using NTSC TV as external monitor to watch PAL dvds played on laptop
By billybadbreaks in forum Newbie / General discussionsReplies: 3Last Post: 1st Mar 2009, 15:27 -
Formatting laptop, how do i know if a laptop has wifi capabilities?
By ricardouk in forum ComputerReplies: 8Last Post: 21st Nov 2008, 10:24 -
DVDs work in desktop PC but not in laptop - previously worked in laptop
By Brent Jewell in forum Newbie / General discussionsReplies: 3Last Post: 6th Nov 2008, 20:40 -
How to watch downloaded HD movies with no HDMI slot on laptop
By whiteshadow in forum Newbie / General discussionsReplies: 3Last Post: 10th Dec 2007, 06:04
