    May 2007
    as anyone seen the following error on SVCD2DVD on startup ?
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.NullReferenceException: Object reference not set to an instance of an object.
    at x3284ccece41ee22b.x210ff09a2516b1a7.x00f758395e988 eed(String xd397bb1e465ce45e, String x9472539ef71e166c)
    at x3284ccece41ee22b.x210ff09a2516b1a7.xb4ff3ab1ae902 6aa(Int32 xbcea506a33cf9111, Int32 xffd6352b2e5d70e3)
    ************** Loaded Assemblies **************
    mscorlib
    Assembly Version: 1.0.5000.0
    Win32 Version: 1.1.4322.573
    CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
    SVCD2DVD
    Assembly Version: 2.1.2474.30185
    Win32 Version: 2.1.2474.30185
    CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/SVCD2DVD.exe
    System.Windows.Forms
    CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
    System
    CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
    System.Drawing
    CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
    DevComponents.DotNetBar
    Assembly Version: 5.9.0.0
    Win32 Version: 5.9.0.2
    CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/DevComponents.DotNetBar.DLL
    AxInterop.CodeLock
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/AxInterop.CodeLock.DLL
    System.Design
    CodeBase: file:///c:/windows/assembly/gac/system.design/1.0.5000.0__b03f5f7f11d50a3a/system.design.dll
    Accessibility
    CodeBase: file:///c:/windows/assembly/gac/accessibility/1.0.5000.0__b03f5f7f11d50a3a/accessibility.dll
    System.Xml
    CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
    Interop.CodeLock
    CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/Interop.CodeLock.DLL
    System.Management
    CodeBase: file:///c:/windows/assembly/gac/system.management/1.0.5000.0__b03f5f7f11d50a3a/system.management.dll
    Interop.QuartzTypeLib
    CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/Interop.QuartzTypeLib.DLL
    Interop.DexterLib
    CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/Interop.DexterLib.DLL
    Interop.NEROLib
    Assembly Version: 1.4.0.0
    Win32 Version: 1.4.0.0
    CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/Interop.NEROLib.DLL
    CustomMarshalers
    CodeBase: file:///c:/windows/assembly/gac/custommarshalers/1.0.5000.0__b03f5f7f11d50a3a/custommarshalers.dll
    AxInterop.MSWEBDVDLib
    CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/AxInterop.MSWEBDVDLib.DLL
    Interop.MSWEBDVDLib
    CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/Interop.MSWEBDVDLib.DLL
    ************** JIT Debugging **************
    To enable just in time (JIT) debugging, the config file for this
    application or machine (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
    <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the machine
    rather than being handled by this dialog.
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Can you try reinstalling? What is your Operating System?
    May 2007
    I have tried re-installing the software, still the same errors on startup, operating system in WIN XP.
  4. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Can you try v2.5? - i will PM you a link.
