I'm thinking of buying a DivX capable DVD player but I'm not sure exactly how they work.
I download a lot of Asian soap operas and game shows for me and my family to watch. I've been converting the AVIs to DVDs but have been told that just getting a DivX capable DVD player would be cheaper and less time-consuming than doing conversions.
So, how do DivX capable DVD players work? Do I put the AVI files on a DVD data disc and pop them in the player?
Do they just play DivX or do they play xVid, H.264 and x264 as well? Most of the stuff I download is in either DivX or xVid.
Will the $60 to $80 Sony, Panasonic, Toshiba DivX capable DVD players be good enough for my purposes?
Results 1 to 14 of 14
They are equipped with the codec to decode the Divx file and then play it as video.Originally Posted by boshu22
Yes.Originally Posted by boshu22
Read the specs for the machine(s).Originally Posted by boshu22
Read the specs for the machine(s). Probably.Originally Posted by boshu22There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
All DivX capable players I've seen, also plays XviD. For H.264/x264 I have no idea. Some chip sets have problem (=don't play) AVIs with QPEL. Can easily be fixed with AVIRecode or AutoGK, but then, the reason for a DivX player is not having to reencode.
/Mats -
It is more accurate to say that such players have a chip dedicated to playing back Divx rather than to say that they have the codec necessary. They do have the codec, but it's on the dedicated chip. No chip = no Divx playback.
There are ZERO standalone DVD players currently that will playback X.264/H.264. This will also require a dedicated chip. Such players would be useful and I suppose eventually they will exist, but they don't at this time.
Philips also makes some DVD players that support Divx. I'd stay away from Sony if it was me.
As Mats stated, various options can be problematic for Divx/Xvid playback. You'll have to test individual players, but among the problems you may find are Divx/Xvid encodes with:
QPel (quarter pixel)
GMC with warp points greater than 1 (it's best to just avoid GMC altogether for best compatibility with DVD players)
Packed bit stream (can be removed without re-encoding, but you do have to create a new copy of the file without it)
Resolutions greater than 720x576
Playback of AC3 or DTS audio may have dropouts if the video bit rate is much above 1800 Kbps. It depends on the chip used to decode Divx. -
What if the DIVX is 2 parts can I just burn both and watch or do I need to join them?
Thanx
You'll get a menu with each of the files listed. Just pick the one you want.
http://www.jarnot.com/twiki/bin/view/Public/DVP642LisaBsAVIGuide
http://home.wi.rr.com/ntngod/dvp642_vs_dvp5140/
http://www.phunkyfish.com/article/4/philips-dvp-596012 -
w0rked slick as slug snot, now can I put the divx into folders or do they all have to be on the dvd\cd root?
Thanx
Most players support folders. There will be some limitations on folder depth, number of files in a folder, the inability to play random order across multiple folders, etc.
The DVD compatibility section on this web site states that this DVD player is DivX compatible but most other forums I've read either makes no mention of this or says it's not compatible. I need to know for sure before I purchase one, so can anyone tell me with certainty that it is or is not DivX compatible? Any help would be greatly appreciated.
JD -
The Philips DVP-5960 is probably the most Divx compatible set-top Divx/DVD player you'll find. Note it is "Divx Ultra" certified.
well i can say that i have the phillips dvd player , and also alot of movies in dvix that i use the dvix player/burner to burn all my downloads has dvix and play them in the phillips machine without prob.
cheers
Is there any DVD players which can play HD DivX?
By kalingga in forum DVD & Blu-ray PlayersReplies: 4Last Post: 8th Jul 2011, 19:06 -
DivX DVD Players
By jm in forum DVD & Blu-ray PlayersReplies: 5Last Post: 28th Feb 2008, 20:30 -
DVD players w/ Divx-HD playback?
By rogerconnery in forum DVD RippingReplies: 8Last Post: 11th Feb 2008, 02:36 -
dvd players with DivX playback?
By iThinkYouBrokeIt in forum DVD & Blu-ray PlayersReplies: 9Last Post: 5th Nov 2007, 19:52 -
Divx DVD players
By greer1988 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 24th Aug 2007, 08:57
