I shutdown my windows xp laptop normally (start-shutdown) and then when i went back to turn it back on, i was greeted with nothing but a black screen. Nothing shows up not even the white fonted- specs of my system...is my laptop dead? or is there a way to fix this?
	is battery dead ? "Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
	no its plugged in with an ac adapter...i hear no harddrive activity its, i just hear one fan going, the sound of the "hum" of the computer is significantly quieter than before.
	ok nvm problem solved i jsut had to fiddle with the memory...thanks anyway
  Top of Windows Live is blacked out in Firefox? not sure why, any ideas?By Denvers Dawgs in forum ComputerReplies: 4Last Post: 8th Feb 2012, 14:21
  Mpeg-4 stutter freeze on laptop 1, laptop 2 plays fine- why?By sevenofone in forum Software PlayingReplies: 1Last Post: 8th Apr 2011, 17:15
  Formatting laptop, how do i know if a laptop has wifi capabilities?By ricardouk in forum ComputerReplies: 8Last Post: 21st Nov 2008, 10:24
  DVDs work in desktop PC but not in laptop - previously worked in laptopBy Brent Jewell in forum Newbie / General discussionsReplies: 3Last Post: 6th Nov 2008, 20:40
  using second laptop as a video in from laptop with broken displayBy joycefitz in forum Newbie / General discussionsReplies: 4Last Post: 19th May 2008, 00:56
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
