I need advice on a DVD Burner. I have an internal one now, but looking to buy an external one. I'm not sure if all burners support dual-layer DVDs (sorry, I'm not smart at this stuff). If they don't, then I need an external one that does support dual-layer DVDs.
Any advice?
At this point in time any DVDwriter not on the clearance tables at major retailers is dual-layer.
And the packaging clearly says so.
Just remember DL media is substantially more expensive than single layer and more likely to generate coasters.
And whatever you do stay away from DVD-R/DL.
External USB DVD burner for $25
By jimdagys in forum ComputerReplies: 0Last Post: 2nd Dec 2011, 01:26 -
Seeking Best Available External CD-DVD Burner
By Frank-0-Video in forum ComputerReplies: 6Last Post: 17th Mar 2010, 09:27 -
Can you enable DMA for an external DVD burner?
By Erasmus in forum DVD & Blu-ray WritersReplies: 9Last Post: 6th Sep 2009, 10:10 -
Which External Dvd Burner To buy???
By ofield in forum DVD & Blu-ray WritersReplies: 9Last Post: 22nd Dec 2007, 01:10 -
What's a good external DVD burner for my iBook G4?
By KeepItSimple in forum MacReplies: 12Last Post: 12th Sep 2007, 09:08
