i am tring to make a 2 camera mix i am having a small problem
i tried to import a video from ym camcorder and there was no audible audio
i tried to import to iMovie and then export/share the iMove project
i then opened the file in FCP and again no audible audio
can someone tell me what file the video format needs to be exported from iMovie and how do i export audio that will open and play in FCP
i tried "full quality" (dv), quicktime mov, and m2v
thanks
Ok let's take it from the top:
You set the Camera to import via FW into FCP?
the video ( and audio) should have been captured in
via the Capture Now to a Bin folder.
Originally, was the audio set for 12bit or 16bit on the camera?
( if 12bit, this would be the problem, as 16bit is what
is accepted in FCP)
Did the camera use an onboard mic, or and external mic?
Did the external mic have proper power at the time of recording?
When you say "audible" audio, is this audio that can be heard,
but not very loudly, or is there NO audio, not even camera hiss?
Lastly, what model camcorder, and what methods are you using
to capture into the computer ( FW, USB, third party capture card,
or third party capture box?)"Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
Take it from earlier than that...
Can you hear sound when playing back the tape from the camera?
What audio settings does the camera show (may need to turn MENU DISPLAY ON for this)?
If it's here, you can get it in somehow, even if it's not correct.
If it's not here, you never successfully recorded it.
Scott -
thanks guys
i can hear and see the audio/video playing on the camcorder
it is 12bit on board mic
played back on a connon zr__ captured to a external FW harddrive
when capturing i can see the video but there is NO audio whats so ever
when i stop capturing i can play the video but there is no audio and the meters do not move
I FIGURED IT OUT - the audio output was set to "play" through my external hd, where the file is being saved
changed that setting to default and/or built in speakers and i can now hear audio on playback
i still can not hear it on capture but i don't care about that
thanks again
Audio glitching on FCP timeline
By Fraser in forum MacReplies: 2Last Post: 12th Jul 2010, 09:22 -
FCP MOV to x264 produces separate Audio and Video MP4 output files?
By skywriter in forum ffmpegX general discussionReplies: 3Last Post: 10th Feb 2010, 15:49 -
FCP: What is the best way to work with .m2v files in a FCP timeline?
By murraymile in forum MacReplies: 1Last Post: 23rd Jan 2009, 15:59 -
VCD to MOV - no audio on FCP
By kj1983 in forum MacReplies: 3Last Post: 9th Jan 2008, 09:05 -
Slow Mo on FCP
By James in HD in forum MacReplies: 4Last Post: 2nd Dec 2007, 21:33
