Results 1 to 28 of 28
  1. Chrissyboy,
    I have installed the 2.5 Beta and can not start the program. I get an error message:The instruction at "0x00000000" referenced memory at "0x000000000". The memory could not be "read".
    I first tried installing this on mt "C" drive not in Program files with the same result. It now resides in Program Files. I am running Windows 2000. I noticed another fellow got the same error message on a Win2K machine, but I didn't see any resolution. Will this not work on Win2K any longer?
    Thanks,
    Mark
  2. So has anyone running Win2K been able to get this new Beta 2.5 to work? Would appreciate your help on this Chrissyboy.
    Thanks,
    Mark
    Apr 2005
    Michigan, USA
    Nope, no luck here, either ...
    I tried installing 2.5 (twice!), even tried using the Repair function, but everytime I attempt to launch the application from the Start menu shortcut, I receive a Windows - Application Error box, stating that "The instruction at "0x00000000" referenced memory at "0x00000000". The memory could not be "read"."
    I'm running Windows 2000 SP4 with .NET Framework both 1.1 and 2.0; I checked Windows Update and no .NET updates were shown as being available.
  4. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Well i have no w2k pc to test it on but i will try to find one. Did v2.1 work on the same box?
    Apr 2005
    Michigan, USA
    Version 2.1 worked for me on Windows 2000.
    If I recall correctly, I loaded 2.5 Beta onto a virtual XP installation and I think it worked correctly ... I'll try again on a virtual installation in the next few days, just to confirm my memory.
    CB - would you please send me the link again vi PM so that I'm sure to have it?
  6. Version 2.1 is still working on my Win2K machine, Chrissyboy.
    Thanks,
    Mark
  7. Chrissyboy,
    Have there been any developements of the problem with running 2.5 in Win2K?
    Mark
  8. Can I get a link to the beta, ive already pmd but got no reply
    Apr 2005
    Michigan, USA
    Anyone heard from ChrissyBoy since 22 May 2007? I haven't had a chance to install 2.5 on virtual XP (assuming I can *find* 2.5!), but it's on my list of things-to-do for this weekend.
  10. Chrissyboy,
    Am patiently awaiting word on whether I can use beta 2.5 with Win2K. Have you found a 2K machine yet? Have you figured out anything yet?
    Mark
  11. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Originally Posted by mwkurt
    Chrissyboy,
    Mark
    Not yet! I will be rebuilding a PC sometime soon - so i will put w2k on it and figure out what is going on.
  12. Thanks for the update Chrissyboy. I look forward to being able to try and work with beta 2.5.
    Mark
  13. Member thepicman's Avatar
    May 2007
    Bottom Of A Gin Bottle
    Chrissyboy,
    Mark
    I would like to add my voice to the W2K v2.5 working version. The speed increases from V2 to V2.5 are quite high on my XP64 machine, but I do most of my work on my W2K machine and am stuck with V2 on that one. Killer program though, thanks!
    TPM
  14. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Well i know what the issue is and I am working on it!
    Apr 2005
    Michigan, USA
    Sorry for the delay ... it looks as if ChrissyBoy found the problem before I could post!
    Just in case it might be of value, here are my findings after installing both version 2.1 and 2.5 beta on a variety of Windows OS installations:
    Version 2.1 (build 2.1.2474)
    Windows 2000 SP4: No problem installing (after installing NET Framework 1.1) or launching SVCD2DVD
    Windows Server 2003: No problem installing (after installing NET Framework 1.1) or launching SVCD2DVD
    Windows XP SP2: No problem installing or launching SVCD2DVD
    Version 2.5 (build 2.5.2693)
    Windows 2000 SP4: No problem installing (after installing Windows Installer 3 and NET Framework 2); Windows Application Error on launch
    Windows Server 2003 : No problem installing (after installing NET Framework 2) or launching SVCD2DVD
    Windows XP SP2: No problem installing (after installing NET Framework 2) or launching SVCD2DVD
    The Server 2003 and XP installations were virtual installs (using Virtual PC 2004); Windows 2004 SP4 is host OS.
    Questions? Let me know if I can provide more information or if I can help troubleshoot the next release candidate.
  16. Member thepicman's Avatar
    May 2007
    KickA$$!
  17. Chrissyboy,
    Any help yet for us W2K users out here?
    Mark
  18. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
  19. I guess perhaps I should have asked my question with a little more clarity, so I'll ask it the way I should have the first time.
    Chrissyboy,
    Any help for us W2K users out here since your reply of 7 days ago since you figured out what the issue was?
    Thanks,
    Mark
  20. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    The problem lies with one of the third party components used in the application. I have alerted the vender to the issue and am waiting for an update after an initial dialog. FYI: previous issues with this vender have been resolved satisfactorily - so I am confident it won't be long before a resolution.... but it is out of my hands at the moment.
  21. Thank you for the information. It is somewhat comforting to be kept abreast of what is going on and knowing that the problem is indeed being looked into.
    Thanks again,
    Mark
  22. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Ok W2K guys.... Can you download the beta from the registered users area to see if your issue is now resolved?
  23. Chrissyboy,
    I went to the registered users area and downloaded the following file:
    v2.5 RC3 build: 2.5.2713, date: 06/06/2007
    Although it says XP/Vista only, I was able to at least open the program now. I will fully test it at a later time.
    Thanks for your help in getting SVCD2DVD to work for us 2K users!
    Mark
  24. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Excellent - l just uploaded the file quickly and did not have time to relabel the page... Will do today.
  25. Member
    Apr 2005
    Michigan, USA
    Downloaded RC3 last night; no problem encountered in installing or launching program in W2K SP4!
    Loaded two (43) minute (350MB) MPEG4 assets into SVCD2DVD, clicked the AutoFit button and let it go ... woke to find an AUDIO_TS and VIDEO_TS folder with 4.30GB of BUP, IFO and VOB files ... sweet! Haven't played the DVD all the way through, but checked about five minutes of each episode using the menu created by SVCD2DVD. I haven't compared the time to convert using v2.1 versus 2.5 yet, maybe tonight.
    Thanks, ChrissyBoy!
  26. Member
    Apr 2005
    Michigan, USA
    Thanks, ChrissyBoy!
    Interesting ... I ran the same assets though version 2.1 this morning, and instead of version 2.5's 4:42 (H:MM), version 2.1 took 7:22 (H:MM)! A speed improvement, indeed! To be honest, there were a ton of buffer underflows this morning (I can't speak to errors encountered in version 2.5 ... where are the logs?).
  27. Click 'Help' and you can access the logs folder.
    Dwight
    "A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
    - Herm Albright
    www.martialconcepts.com
  28. Member
    Apr 2005
    Michigan, USA
    Thanks, Dwight!
    I didn't even think of looking at the Help dropdown!
    Now that I've found the logs, the v2.5RC3 run did not encounter buffer underflows (at all!) the way that v2.1 did with the same source ... interesting! Now I think I'm thinking of rerunning the v2.1 process again to see if those buffer underflows are seen again.
    In any case, version 2.5RC3 is running fine on my W2K installation! Thanks again, ChrissyBoy!
