I am using Adobe Premiere Pro and I've added my video divx files to make a new dvd. However, when I burn the DVD, even using the lowest compression, I can only fit a small amount of video. How come I cannot compress it more to crap more episodes? It can only hold about 4 hours worth, when I know that at a lower quality I could cram more. However, it won't let me.
Results 1 to 10 of 10
Why did you buy Premiere Pro to do this?Originally Posted by epsilon9090
What is your project format?
4 hrs Divx would generate something like 58GB temp files even at DV compression.
Uncompressed project settings would fill a 300 GB drive.
Whatever you do, DVD MPeg2 encoding is going to stress at 2 hours unless you drop resolution. -
Will dropping resolution render the DVD playable in most players? My files are only about 520x380 and they are of pretty low quality. Does it not work because Divx is much more efficient than MPeg2, so cramming an equivalent length takes more space?
See what is DVD?Originally Posted by epsilon9090
https://www.videohelp.com/dvd
Playable DVD resolutions are 720x480/576, 704x480/576, 352x480/576 or 352x240/288
at various bitrates and audio specifications.
DVD is much less compressed.
At extremes, DVD will fit 1Hr at high quality 720x480 MPeg2 to about 7hrs at similar to VCD 352x240 MPeg1 (48kHz audio required). -
So I can still encode an MPEG1 DVD? How would I do that with premiere, though?
You haven't told me your Premiere version or project format.Originally Posted by epsilon9090
With DV format your 7 hrs. Divx needs decompression to about 120GB DV tmp files then encoded under "Export Timeline" to MPeg1. -
And then I can import that Mpeg 1 file into something like Nero and burn the DVD? Will Nero re-encode the file, or straight up convert it into vob and burn it?
Some versions of Premiere will author a simple DVD. Others just create the MPeg file that then requires a DVD authoring program to create the Video_TS folder (VOB, IFO, BUP files) and a burning program to burn the DVD.Originally Posted by epsilon9090
I still maintain that Premiere Pro is the worst program to do what you want to do. You shouldn't have paid $800 ($279 academic) for that. You could do it better with simple tools @ less than $120. -
Premeire Pro is good for compositng, filters or effects from original work but for simple divx cuts it carries too much overhead.
Try VirtualDubmod+TMPeg DVD Author. See the tutorials.
Can you import from Adobe After Affects to Adobe Premiere Pro?
By Devilsadvocate in forum EditingReplies: 9Last Post: 29th Feb 2012, 22:43 -
Adobe Premiere Pro 2 Help
By slicebogey in forum EditingReplies: 6Last Post: 9th May 2011, 18:21 -
Adobe Premiere Pro CS3 & Vegas Pro help
By KS89 in forum EditingReplies: 1Last Post: 8th Sep 2009, 23:52 -
SxS Pro card file MXF to DVD using Adobe Premiere Pro CS3
By Fary4u in forum Video ConversionReplies: 8Last Post: 20th Jul 2009, 10:00 -
Should I get Adobe Premiere Pro CS4? - Upgrade from Pro 1.5
By vid83 in forum Newbie / General discussionsReplies: 0Last Post: 22nd Feb 2009, 18:10
