Results 1 to 11 of 11
    May 2007
    I'm not able to play copied dvd's on my computer. My PC will read and play all store bought DVDs but will not read or detect any copied dvds. any suggestions? I have a Pioneer DVR -106D Player/ burner.
    Apr 2005
    Michigan, USA
    Where did the copied DVDs come from (friends, copies you made on your PC)? How were the copies produced (software, procedure, media)?
    Or shall we just just consult our Ouija boards?
    May 2007
    I copied them with shrink and dvd dycrypter. on my pc and now cant seem to get my PC to recognize any thing that is a copy. it will read and play everything else CD's Store bought DVD's but will not play or recognize anything that is a copy.
  4. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Does it read any DVD-R? I mean - does it not play your Video DVD backups, or doesn't it recognize DVD-R (and/or +R) disks at all?
    /Mats
    May 2007
    it seem that it is not reading recordable media. Even though the DVR is capable of reading Bot DVD+ R and -R.
  6. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Then I'd diagose it as hardware problem - Your DVD reader is on its last leg.
    /Mats
    May 2007
    OK I went to the Pioneer web site and got the current drivers for my model. I can now burn a movie with dycrypter again. The burner is now recognizing blanks and able to burn. Im waiting to see if it will now be able to view what is burned on a recordable disc.
  8. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    So - You've had problems backing up to DVD-R too?
    /Mats
    May 2007
    No Dice. It failed to close out the disc when done.
    May 2007
    No I have not used DVD-R Media for a while now. But I used to be able to use it to play and write
    May 2007
    You Might be right. I think my DVR is on its last leg when it comes to reading copied dvds and dvds recorded from stand alone players. I might have to replace it.
