This is causing me to make xViD/Lamemp3 videos in which the video and audio length mismatch. It doesnt matter if i encode with the Lame codec or FrauhofferII, or which app i use to create the mp3, it ends up losing some ms. This is creating out-of-sync videos.
I've tried changing the sampling frequency from 48Khz to 44.1Khz, and different bitrates from 128Kbps to 320Kbps but no difference.
If i direct stream the AC3, the stream lengths match and sync is preserved.
I have updated FFDSHOW and the AC3 Filter/Decompressor but it still happens.
Does this sound familiar? Any suggestions?
Results 1 to 9 of 9
"Youth is wasted on the young."
Save direct stream with AC3 so the audio is in sync.
Download the script in this thread and run the Avi_Gain_Regular.bat file on your AVI/AC3 file.
https://forum.videohelp.com/topic314909.html
That'll convert the audio to MP3 and remux it. -
Seems like you do everything with scripts Soopa, don't you do anything manually nowadays?
Lets see, Avi_Gain_Regular.bat u say...
OOOOOOOOOOOOOOOMMMMMMMMMMGGGGGGGGGGGGGGGGGGGGGGGGG GGGGGGGGGG
IT WORKED!!! Audio is the same length as the original...
Your MS-DOS .bat file just did what Cool Edit Pro/Soundforge/Audacity could not, and encode a wav/ac3 to mp3 with no file length change... Is the trick Normalising it?
I love you Soopa. I felt a tear swelling then!
Can u explain how that worked? Its pretty loud now, can i increase the volume only slightly? And why 224Kbps... any chance u can make me a new .bat with 128Kbps and just a small volume increase?
I'll be using AVI Gain for all my movie mp3 encodes now
"Youth is wasted on the young." -
Sure thing, but you can change the info just as easily.
Just open up Notepad and open the .BAT file . Look for these lines:
and change to this (the "rem" command will disable the audio normalizing, so in theory it shouldn't be louder than the source any longer):
Thanks for your kind words, happy to help out.
Cool that worked, theres only one problem. Your .Bat files seem to fill up the User Metadata with a heavy spam of the codec, in this case DivX, when i hover my mouse pointer over it, it goes off the screen.
Whats going on there? Can u fix? Or is there a way to delete the Junk data? Is it taking up much space?
Also from the things u are doing to the sound, can u summise why this mp3 encoder works properly and why everything else i use doesn't?"Youth is wasted on the young." -
Aha...That's the DivX Multiplexer at the end creating that garbage. Talk about giving themselves props. Bummer, because it is a really good muxer. If you don't absolutely need to change it, the extra junk might be worth the quality of mux. I think there are some apps out there that would let you clean it out.
Delete the blue line, and replace it with the green one.
What is that doing, using the FFMpeg encoder instead? Okay, lets try it!
Thats no good, it created a VBR mp3 so i got a warning on loading and the length is different again... lol
Can u specify CBR audio?
Don't worry about the Junk Metadata, it gets erased if i do anything else to the file.
THANKYOU AGAIN 8)"Youth is wasted on the young."
Converting AC3 to MP3 on AVI
By hilario in forum Video ConversionReplies: 22Last Post: 18th Jun 2011, 01:37 -
Converting AC3 in a video to MP3
By LittleJohny in forum Video ConversionReplies: 4Last Post: 4th Jun 2010, 20:21 -
Converting AAC to AC3 (for DVD authoring), losing audio
By senorroboto2k5 in forum AudioReplies: 3Last Post: 16th Feb 2010, 18:03 -
Audio out of sync after converting AC3 to MP3 in AVI with VD
By huykin in forum AudioReplies: 6Last Post: 1st Oct 2009, 13:27 -
Converting .WMV to .MPG and losing audio/picture
By frenchdb in forum Video ConversionReplies: 1Last Post: 29th Jun 2008, 20:42
