  1. The first queston has to do with TMPGE. I read under the converting avi to vcd that you can use filters. I have version 2.2 of TMPGE and I can't figure out where the filter adjustments are. I have looked and even went to the website. Could you tell me where they are.
    And the second question is that I made a VCD that was perfect. It played on my friends dvd player in his computer fine. And it played in my firiends Console DVD player fine except that it was a subtitled anime and the subtitle were getting cut off on the corners of the screen. What and how should I set to fix this.
    Thanks a lot!
    Feb 2001
    Berlin, Germany
    1] If you want to use TMPG's filters, go to setting > advanced > doubleclick on the filter
    2] Search the forum for TV overscan
  3. Thanks a lot!!!!
