Just converting all Liverpool Champions league matches this season on to Dual Layer DVD
i am using Ulead movie factory
However for some reason when converted and put onto Dual Layer DVD there is sound but no Picture
All my codecs are up to date (I think)
it has no picture on the Dual layer DVD when played on a DVD player or played on the computer
Also the time it takies to convert and burn in Ulead is about 20 hours on this the file
Before i start the conversion the files are in mp4 format - is this a problem
Anyone help on what this could be
Sooty
I havnt tried it on a single layer DVDOriginally Posted by guns1inger
i have only tried it on Dual and get Picture -
Basic trouble shooting first
1. If you save the authored DVD to your HDD first, and play it with a software player, does it play correctly ?
2. Are you using Verbatim DL discs ? Collective experience at this forums shows Verbatim to be the only truly reliable discs, although a small number of people have success with other brands.Read my blog here.
Ulead DVD Movie Factory 6 Plus
By orientaldragon in forum Newbie / General discussionsReplies: 8Last Post: 2nd Apr 2011, 09:48 -
By Ragamuffin in forum Authoring (DVD)Replies: 3Last Post: 6th Oct 2009, 13:22 -
Ulead DVD Movie Factory and Vista
By qpskfec in forum Authoring (DVD)Replies: 1Last Post: 4th Jan 2008, 15:08 -
Ulead DVD Movie Factory...
By mmitchell_houston in forum Authoring (VCD/SVCD)Replies: 225Last Post: 23rd Oct 2007, 11:59 -
By koberulz in forum Newbie / General discussionsReplies: 10Last Post: 26th Jun 2007, 08:14
