Hi,
This is my first post, so please bear with me.
After ALOT of trouble trying to get the update to install...I finally got it to go in without a hitch.
I have a problem I am hoping someone can help me with. I am using Maxell DVD+R 16x and a Sony DVD RW DRU-710A burner. I have used Nero for years without alot of trouble. I usually use Verbatim DVD's but I ran out, so I bought a small pkg (15) of these Maxell. So far, I have made 7 coasters!
The burn goes successfully...but when it does the data verification, it doesn't seem to move the percentages, the "read" bar at the bottom doesn't move...and soon it will give an error. The last one I did, Nero gave up on!!! It said there were toooooo many errors!
I use the data verification because I want to make sure I don't give my mother or friends a "dud" of a copy. I heard you can verify it some other way, but I'm not too computer literate, so I don't know how to go about it. Maybe you can give me some instructions on that too, please?
Since you have Nero, you might try Nero CD-DVD Speed with one of your discs. http://www.cdspeed2000.com/
Verification isn't foolproof. Do the DVDs play properly or at all?
Do you have the full Nero or the OEM version that came with the burner or PC?
I would try ImgBurn instead. It's one one the best burning programs out there for DVDs and it's freeware.
And with Nero, you could try posting the Nero burn log. That should tell you where the failure occurred. Blank out the Nero serial number and the video titles.
Nero 7 doesn't have too good a reputation.
And welcome to our forums. -
Hi Redwudz!
Thanks for responding. I appreciate the help.
The DVD's do NOT play at all in the stand alone player (wrong disc error), and it just hangs in the computer drive and does nothing (but blink like crazy)!
I have the 7 CD, but the 7850 is the free update for it.
I am going to look into ImgBurn like you suggested. I just hope it is easy to use because I'm technologically challenged!
I am almost wanting to say it's the Maxell discs, but I dunno.
Anyway, here's the log. Thanks for looking at it for me. I see the same error all the way through it.....(KEY_MEDIUM_ERROR) but I don't know what that means.
Windows XP 5.1
IA32
WinAspi: -
NT-SPTI used
Nero Version: 7.8.5.0
Internal Version: 7, 8, 5, 0
Recorder: <SONY DVD RW DRU-710A> Version: BYX5 - HA 1 TA 0 - 7.8.5.0
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <E-IDE CD-ROM 52X L >Version: 31 - HA 1 TA 1 - 7.8.5.0
=== Scsi-Device-Map ===
DiskPeripheral : ST3300831AS atapi Port 1 ID 0 DMA: On
DiskPeripheral : ST3300831AS atapi Port 2 ID 0 DMA: On
CdRomPeripheral : SONY DVD RW DRU-710A atapi Port 3 ID 0 DMA: On
CdRomPeripheral : E-IDE CD-ROM 52X L atapi Port 3 ID 1 DMA: On
=== CDRom-Device-Map ===
SONY DVD RW DRU-710A E: CDRom0
E-IDE CD-ROM 52X L F: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 1023MB (1048044kB)
Free physical memory: 822MB (842016kB)
Memory in use : 19 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
21.5.2007
UDF/ISO compilation
12:53:11 AM #1 Text 0 File SCSIPTICommands.cpp, Line 411
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
12:53:11 AM #2 Phase 112 File dlgbrnst.cpp, Line 1762
DVD-Video files reallocation started
12:53:11 AM #3 Phase 114 File dlgbrnst.cpp, Line 1762
DVD-Video files reallocation completed (no file modified)
12:53:11 AM #4 Text 0 File Isodoc.cpp, Line 6608
UDF document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
UDF Mode : UDF/ISO bridge
UDF Options : automatic
UDF Revision : 1.02
UDF Partition Type : physical
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : FALSE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
12:53:11 AM #5 Phase 111 File dlgbrnst.cpp, Line 1762
DVD-Video files sorted
12:53:11 AM #6 ISO9660GEN -11 File Geniso.cpp, Line 3343
First writeable address = 0 (0x00000000)
12:53:12 AM #7 ISO9660GEN -11 File Geniso.cpp, Line 3343
12:53:12 AM #8 Text 0 File Burncd.cpp, Line 3499
Turn on Disc-At-Once, using DVD media
12:53:12 AM #9 Text 0 File DlgWaitCD.cpp, Line 307
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 2286127 (508:01.52, 4465MB)
12:53:12 AM #10 Text 0 File DlgWaitCD.cpp, Line 319
Write in overburning mode: NO (enabled: CD)
12:53:12 AM #11 Text 0 File DlgWaitCD.cpp, Line 2949
Recorder: SONY DVD RW DRU-710A, Media type: DVD+R
Disc Manufacturer ID: RICOHJPN, Media Type ID: R03, Product revision number: 4
Disc Application Code: 0, Extended Information Indicators: 7
12:53:12 AM #12 Text 0 File DlgWaitCD.cpp, Line 493
>>> Protocol of DlgWaitCD activities: <<<
12:53:12 AM #13 Text 0 File ThreadedTransferInterface.cpp, Line 793
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2286128 (2286128) = #2286128/508:1.53
relocatable, disc pos for caching/writing not required/ required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2286128 blocks [E: SONY DVD RW DRU-710A]
12:53:12 AM #14 Text 0 File ThreadedTransferInterface.cpp, Line 995
Prepare [E: SONY DVD RW DRU-710A] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4681990144, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|__ ____NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 2286128 | 0 | 0x00
2286128 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
12:53:12 AM #15 Text 0 File SCSIPTICommands.cpp, Line 209
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
12:53:12 AM #16 Text 0 File Burncd.cpp, Line 4278
Caching options: cache CDRom or Network-Yes, small files-No (<64KB)
12:53:12 AM #17 Phase 24 File dlgbrnst.cpp, Line 1762
Caching of files started
12:53:12 AM #18 Text 0 File Burncd.cpp, Line 4397
Cache writing successful.
12:53:12 AM #19 Phase 25 File dlgbrnst.cpp, Line 1762
Caching of files completed
12:53:12 AM #20 Phase 36 File dlgbrnst.cpp, Line 1762
Burn process started at 8x (11,080 KB/s)
12:53:12 AM #21 Text 0 File ThreadedTransferInterface.cpp, Line 2721
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
12:53:12 AM #22 Text 0 File Cdrdrv.cpp, Line 9859
---- Disc Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R (10), Part Version: 1.0x (1)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Disc Application Code: 0 / 0 h
Extended Information indicators: 7 h
Media type ID: R03
Number of Physical format information bytes in use in ADIP up to byte 63: 56
Media Specific [16..63]:
00 00 07 52 49 43 4F 48 - 4A 50 4E 52 30 33 04 38 ...RICOHJPNR03.8
23 54 37 13 00 44 73 00 - 84 6D 15 15 0B 0B 08 08 #T7..Ds..m......
01 19 1B 0C 0C 0C 0D 01 - 00 00 00 00 00 00 00 00 ................
12:53:12 AM #23 Text 0 File DVDR.cpp, Line 6977
Drive: SONY DVD RW DRU-710A
Book Type request [LO], rev 1: DVD-ROM
Changing the Book Type was finished successfully, return code 0
12:53:12 AM #24 CDR -1207 File DVDR.cpp, Line 6356
Book Type automatically set to: DVD-ROM
12:53:12 AM #25 Text 0 File DVDPlusRW.cpp, Line 674
Start write address at LBA 0
DVD high compatibility mode: Yes
12:53:12 AM #26 Text 0 File ThreadedTransfer.cpp, Line 269
Pipe memory size 83836800
1:01:15 AM #27 Text 0 File WriterStatus.cpp, Line 113
<E: SONY DVD RW DRU-710A> start writing Lead-Out at LBA 2286128 (22E230h), length 0 blocks
1:01:45 AM #28 Text 0 File DVDPlusRW.cpp, Line 934
EndDAO: Last written address 2286128
1:01:45 AM #29 Text 0 File DVDR.cpp, Line 6977
Book Type request [LO], rev 1: DVD+R
1:01:45 AM #30 Phase 37 File dlgbrnst.cpp, Line 1762
Burn process completed successfully at 8x (11,080 KB/s)
1:01:45 AM #31 Phase 78 File dlgbrnst.cpp, Line 1762
Data verification started
1:01:48 AM #32 Text 0 File ThreadedTransfer.cpp, Line 269
Pipe memory size 590400
1:01:59 AM #33 SPTI -1128 File SCSIPassThrough.cpp, Line 179
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1128)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 00 10 00 00 10 00 00 00
Sense Area: 0x70 00 03 00 00 00 00 0A 00 00 00 00 11 05
Buffer x08346a40: Len x8000
1:02:08 AM #34 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 00 20 00 00 10 00 00 00
1:02:13 AM #35 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 00 30 00 00 10 00 00 00
1:02:22 AM #36 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 00 40 00 00 10 00 00 00
1:02:27 AM #37 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 00 50 00 00 10 00 00 00
1:02:37 AM #38 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 00 60 00 00 10 00 00 00
1:02:41 AM #39 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 00 70 00 00 10 00 00 00
1:02:50 AM #40 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 00 80 00 00 10 00 00 00
1:02:55 AM #41 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 00 90 00 00 10 00 00 00
1:03:04 AM #42 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 00 A0 00 00 10 00 00 00
1:03:10 AM #43 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 00 B0 00 00 10 00 00 00
1:03:19 AM #44 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 00 C0 00 00 10 00 00 00
1:03:23 AM #45 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 00 D0 00 00 10 00 00 00
1:03:32 AM #46 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 00 E0 00 00 10 00 00 00
1:03:37 AM #47 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 00 F0 00 00 10 00 00 00
1:03:46 AM #48 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 01 00 00 00 10 00 00 00
1:03:51 AM #49 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 01 10 00 00 10 00 00 00
1:04:00 AM #50 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 01 20 00 00 10 00 00 00
1:04:04 AM #51 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 01 30 00 00 10 00 00 00
1:04:16 AM #52 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 01 50 00 00 10 00 00 00
1:04:16 AM #53 SectorVerify 20 File Cdrdrv.cpp, Line 11165
Read errors from sector 16 to 319
1:04:26 AM #54 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 01 60 00 00 10 00 00 00
1:04:31 AM #55 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 01 70 00 00 10 00 00 00
1:04:40 AM #56 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 01 80 00 00 10 00 00 00
1:04:45 AM #57 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 01 90 00 00 10 00 00 00
1:04:54 AM #58 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 01 A0 00 00 10 00 00 00
1:04:58 AM #59 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 01 B0 00 00 10 00 00 00
1:05:07 AM #60 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 01 C0 00 00 10 00 00 00
1:05:12 AM #61 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 01 D0 00 00 10 00 00 00
1:05:23 AM #62 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 01 E0 00 00 10 00 00 00
1:05:28 AM #63 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 01 F0 00 00 10 00 00 00
1:05:37 AM #64 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 02 00 00 00 10 00 00 00
1:05:41 AM #65 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 02 10 00 00 10 00 00 00
1:05:50 AM #66 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 02 20 00 00 10 00 00 00
1:05:54 AM #67 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 02 30 00 00 10 00 00 00
1:05:58 AM #68 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 02 40 00 00 10 00 00 00
1:06:00 AM #69 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 02 50 00 00 10 00 00 00
1:06:04 AM #70 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 02 60 00 00 10 00 00 00
1:06:06 AM #71 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 02 70 00 00 10 00 00 00
1:06:10 AM #72 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 02 80 00 00 10 00 00 00
1:06:12 AM #73 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 02 90 00 00 10 00 00 00
1:06:16 AM #74 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 02 A0 00 00 10 00 00 00
1:06:18 AM #75 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 02 B0 00 00 10 00 00 00
1:06:22 AM #76 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 02 C0 00 00 10 00 00 00
1:06:24 AM #77 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 02 D0 00 00 10 00 00 00
1:06:27 AM #78 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 02 E0 00 00 10 00 00 00
1:06:29 AM #79 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 02 F0 00 00 10 00 00 00
1:06:33 AM #80 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 03 00 00 00 10 00 00 00
1:06:36 AM #81 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 03 10 00 00 10 00 00 00
1:06:40 AM #82 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 03 20 00 00 10 00 00 00
1:06:42 AM #83 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 03 30 00 00 10 00 00 00
1:06:45 AM #84 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 03 40 00 00 10 00 00 00
1:06:47 AM #85 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 03 50 00 00 10 00 00 00
1:06:50 AM #86 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 03 60 00 00 10 00 00 00
1:06:52 AM #87 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 03 70 00 00 10 00 00 00
1:06:56 AM #88 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 03 80 00 00 10 00 00 00
1:06:58 AM #89 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 03 90 00 00 10 00 00 00
1:07:01 AM #90 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 03 A0 00 00 10 00 00 00
1:07:03 AM #91 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 03 B0 00 00 10 00 00 00
1:07:07 AM #92 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 03 C0 00 00 10 00 00 00
1:07:09 AM #93 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 03 D0 00 00 10 00 00 00
1:07:12 AM #94 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 03 E0 00 00 10 00 00 00
1:07:14 AM #95 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 03 F0 00 00 10 00 00 00
1:07:19 AM #96 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 04 00 00 00 10 00 00 00
1:07:21 AM #97 SPTI -1128 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 00 00 00 04 10 00 00 10 00 00 00
1:07:21 AM #98 CDR -1222 File Writer.cpp, Line 200
Verification aborted, too much errors
1:07:21 AM #99 Phase 81 File dlgbrnst.cpp, Line 1762
Data verification failed
1:07:21 AM #100 Text 0 File SCSIPTICommands.cpp, Line 254
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
1:07:28 AM #101 Text 0 File Cdrdrv.cpp, Line 11214
DriveLocker: UnLockVolume completed
1:07:28 AM #102 Text 0 File SCSIPTICommands.cpp, Line 411
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option) -
Verification is the only industry accepted means of determining a successful copy.
From all of the information you have provided, you do not have a successful copy.
I do not suspect a Nero failure. I do suspect your Maxell Media (Ricoh)and your SONY (rebadged Lite-on) drive do not care for each other.
For a start, you should determine whether your drive has the latest firmware, and if it does not, you should update. You may not have a proper write strategy for this media.
HDD Data Recovery - from Pioneer DVR-530H-S failed hard drive
By fortisMilvus in forum DVD & Blu-ray RecordersReplies: 17Last Post: 15th Feb 2025, 02:20 -
DVD Decrypter error:Failed to set data for "DVDDecrypterPlayMovieOnArr
By rachelsmiley in forum DVD RippingReplies: 17Last Post: 22nd Dec 2017, 11:40 -
nero burning failed
By KristijanR in forum Newbie / General discussionsReplies: 1Last Post: 6th Jul 2009, 01:10 -
Nero failed burning DVD
By DuBsTaR in forum Newbie / General discussionsReplies: 3Last Post: 6th Jan 2008, 14:15 -
failed to read the video data from the source file (80004005)
By tertill in forum Video ConversionReplies: 3Last Post: 31st Oct 2007, 09:26
