I recently got the Pioneer A03 DVD-R/RW and have been trying to figure the highest capture bitrate possible for a 123min video. I am capturing directly to mpeg2 using ATI All In Wonder Radeon, 720x480 NTSC 5.53 MB/sec VBR , 44.100 KHz 16 bit Stereo audio, 0 Motion Estimation Quality and 1 for Horizontal and Verticle Motion Estimation Search Ranges. The captured .mp2 file is 3.72 Gig. Well, after I de-multiplex, convert audio to wave, convert audio to 48000 Hz 320kbs, author with SpruceUP, my DVD comes in well under 4.3 Gig. Is there a bitrate calculator out there that can help. I've searched and searched, found bitrate calculators, but none that really help me. If anyone has any info please pass it on, it would be greatly appreciated.
if I calculate the average bitrate should be about 4700 kbit/s using the vcdhelp bitrate calculater and it is kinda correct...but you are using vbr and you then never now how exactly big the output will be.
or else calculate yourself
( dvdrsize - (audio*videolength) ) / videolength = video bitrate. -
Spiderman:
I have an AIW and a Dazzle 1 - I recently ordered the Dazzle II. I have not been able to get the AIW to capture or even play TV. Basically I'm hoping the MPEG-2 output of Dazzle 2 will be suitable for high quality SVCD creation, so I'm curious to know if you've tried it and what were the results?
Can I capture/copy DV directly to DVD MPEG2?
By shina00 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 17th Nov 2011, 07:16 -
mpeg2 50mbps capture questions
By the1selecta in forum Capturing and VCRReplies: 13Last Post: 30th Oct 2010, 22:22 -
By Gew in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 28th Mar 2009, 07:21 -
What do I get for my needs - Mpeg2\Ac3 capture?
By Castor troy in forum Portable VideoReplies: 1Last Post: 20th Apr 2008, 18:56 -
DivX and MPEG2 capture devices
By Arcturus in forum Capturing and VCRReplies: 18Last Post: 25th Aug 2007, 00:49
