I am guessing that this issue has been discussed elsewhere but I don't seem to know the correct terminology to find the answers I am looking for so I'll go ahead and ask.
I have created a few episode style DVDs in NeroVision Express 3.1.0.25 with a main menu and 4 sub-menus, one for each episode. Each sub-menu has buttons to jump to each of the 6 chapters that I created for each episode. My problem is that when I select an episode from the main menu, the highlighted button on that page corresponds to the episode's position on the main menu. For example, if I select episode 2, chapter 2 on the menu for that episode is highlighted, if I select episode 3, chapter 3 is highlighted on the menu for that episode, etc.
Is there some way to make chapter 1 the highlighted button for each episode either in NeroVision or by some sort of menu editing software?
Thanks.
In DVDRemake Pro you can set selection of any wanted button by going to menu display pane, right-click on background => edit button set attributes => autoselect button # on menu start.
Then file/'export modified files', backup and replace ifo's. Fast and easy. -
Thanks for the replies. I'll give PgcEdit's button editor a shot and see what happens.
Edit: I just figured out how to use the PgcEdit button editor to make button number one the default button on all of my sub-menus. Thanks for the tip!
I'm not quite sure what "before skipping off, push SPRM 8 with 1024 with a Set HL_BTN command" means however.
menu button didn't work
By pcb in forum Authoring (DVD)Replies: 6Last Post: 13th Oct 2010, 15:07 -
DvdAuthorGui menu Button
By sambat in forum Authoring (DVD)Replies: 7Last Post: 15th Mar 2010, 07:04 -
Edit dvd menu button
By canaQ in forum Authoring (DVD)Replies: 8Last Post: 24th Feb 2010, 07:13 -
Highlighted Mark in Menu
By stecaro in forum DVD RippingReplies: 2Last Post: 22nd May 2009, 14:16 -
PGCEdit question: setting menu button highlight positions for letterbox
By Alex_ander in forum Authoring (DVD)Replies: 10Last Post: 5th Jun 2008, 11:55
