Hey, I just now noticed this feature in CCE in the toolbar. It is on Standard by default, but should I change it? I am backing up NTSC DVDs, so should I change it to NTSC. Or should I just always leave it on Standard? What difference does it make? Thanks!
In my CCE version 'Standard' is the same as 'NTSC DVD'. Looks like they called it that way for reference in case other template is edited and saved.
For an NTSC encoding it is better to customize a default NTSC template: if you select PAL, you'll have to change not just framerate, but such things as GOP structure etc. -
I agree. I don't use any of them. I make my own, and set up one of them as the Standard (or default), for the kinds of encodes I do most often (NTSC/Progressive).
A big difference. If I remember correctly, that Standard one is for interlaced 29.97fps NTSC encoding, and 1-pass CBR. If you have a progressive 23.976fps source for which you'd rather use multi-pass VBR encoding, you're screwed. -
Well, I am using DVD Rebuilder with CCE to backup my NTSC DVDs. Do I even need to go in to CCE and change anything or will just leaving it as standard be fine?
Need help selection BD player
By music5_5 in forum DVD & Blu-ray PlayersReplies: 7Last Post: 11th Sep 2011, 21:29 -
Software selection
By Sinnocence in forum Newbie / General discussionsReplies: 5Last Post: 17th Jul 2011, 07:55 -
XP OS selection at startup.....
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 17th Jul 2009, 00:55 -
Help with camcorder selection, please!
By odalager in forum Newbie / General discussionsReplies: 11Last Post: 7th May 2008, 16:38 -
Looking for a music selection
By gadgetguy in forum Off topicReplies: 7Last Post: 2nd Jun 2007, 19:08
