I have just finished authoring a DVD (VIDEO_TS folder) with Menus & Chapters, preceded by considerable editing & trimming. It plays on a TV but the field order is apparently reversed from that produced by the original DVD camera. As a result, any motion in the picture tends to break up. I don't want to spend hours redoing all this just because the field order is wrong. Is there any easy way to change TFF to BFF for this DVD?
Perhaps DVD Patcher. I know Restream will, but not on VOB files.
Where in the process did the field order change ? Usually this only happens when video is re-encoded.Read my blog here.
Also, both it and Restream work on MPEG only.
So, demux (PGCDemux), change the field order (ReStream), remux (Muxman), and stick the fixed DVD back into the original DVD (VobBlanker). Nothing hard about that. Just takes some time. -
Thanks gunslinger. I was afraid of that. Maybe someone else will come up with a solution.
Well, manono, I appreciate the very complete reply. Once I've downloaded all those programs I'll give it a try. But, not until tomorrow. I'm a little bushed right now.
Field Order
By Tafflad in forum Authoring (DVD)Replies: 9Last Post: 30th Jan 2010, 01:38 -
How do I change the field order on Moviefactory 5? Please!
By jayndani in forum Newbie / General discussionsReplies: 1Last Post: 12th Jan 2009, 07:42 -
How do I change the field order in Moviefactory 5?
By jayndani in forum Newbie / General discussionsReplies: 1Last Post: 12th Jan 2009, 05:42 -
Determining field order
By dadrab in forum Video ConversionReplies: 2Last Post: 4th Oct 2007, 16:09 -
Field order?
By miamicanes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 12th Sep 2007, 17:14
