Is it possible to convert nrg (nero image file) to MPEG-2 or DVD, I am problems converting it does anyone know what program can convert this file, thanks in advance for any help received.
Ricky
".NRG" files are Nero CD or DVD image files. Burn it to a blank DVD using Nero or Imgburn (i think).
If you just want to extract the audio/video tracks then either use DAEMON Tools to mount it as a virtual DVD or burn it to a blank DVD. Then use something like DVDdecrypter to extract any tracks you want. -
An image file can contain anything so you must first extract the content from the image and then convert the video. Use for example daemon tools and mount it as a drive or extract with isobuster. Then convert the video...if you don't know how please tell us what files the nrg contained.
Use Nero's ImageDrive, look in the start menu, or in the start smart menu, expand the left edge and look through the tools. Then you can access the data.
.nrg file conversion
By PULINC in forum Video ConversionReplies: 3Last Post: 7th Apr 2012, 02:10 -
.nrg file
By firoril in forum Video ConversionReplies: 1Last Post: 13th Jun 2008, 02:25 -
How to convert NRG files to AVI?
By Rude in forum Newbie / General discussionsReplies: 6Last Post: 2nd Apr 2008, 13:05 -
NTSC nrg to Pal
By charyuop in forum Video ConversionReplies: 7Last Post: 18th Dec 2007, 12:21
