Hi all!
I need to create an AVI or any video file type (that i can use to burn a DVD-R) and play in a standalone DVD with all the actions i make in my desktop area. I will play a game and need to save that in in a file to create the DVD. I already try CAMSTUDIO 2.0 but after i try all the settings i still loose frames and also picture quality.
Is there any other software that i can use?
My system is:
P4 2.4 GHZ
512 RAM Memory
Win XP SP2
I am trying to run GALAGA game in the MAME Emulator
Any idea?
THX
hgtvg.
Hi Baldrick!
You are rightI tried all progs listed in the tools section but none worked. When using MAME emulator i still have drop frames problems. I also tried to use ATARI Emulator but the result was worst. Did not capture
I will be forced to attach my DVD Recorder in my PC to do it
Thanks for all your help!
hgtvg.
Intensity Shuttle constantly detects Blackmagic Desktop Video software
By Zork787 in forum Capturing and VCRReplies: 1Last Post: 2nd Sep 2011, 13:12 -
Desktop record software?
By neworldman in forum ComputerReplies: 1Last Post: 21st Sep 2010, 01:40 -
Capture desktop of another PC/notebook
By cardenal in forum Video Streaming DownloadingReplies: 1Last Post: 26th Jul 2009, 22:55 -
Good Remote Desktop Software?
By a1i3n777 in forum ComputerReplies: 18Last Post: 26th Dec 2008, 14:06 -
Recommend a free Virtual Desktop software?
By Des in forum ComputerReplies: 10Last Post: 27th Aug 2007, 10:43
