    May 2007
    I need the last part a VOB file and would like to convert it to MPEG, but there is a corruption approx half way through the video. I tried ISO buster, it will extract the file but the error remains in the file preventing me from converting it to MPEG. I tried the DVD to AVI DIVx converter because it allows you to clip the parts from the VOB file and convert, but it does not recognize anything in the file after the error occurred. I can actually view the entire VOB file in POWER DVD, even with the corruption. But anytime I use any of the tools to try to convert, I get the error.
    Any idea how I can clip the corruption out of the VOB file so I can convert to MPEG for editing?
    lp
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    recopy it off your dvd
  3. Member Marvingj's Avatar
    Apr 2004
    Death Valley, Bomb-Bay
    Try FixVTS
    http://www.absolutevisionvideo.com
    BLUE SKY, BLACK DEATH!!
    May 2007
    That worked, thank you very much
    lp
