Up here in Canada Future Shop has a Sony KDS60A2000 60" 1980p SXRD Widescreen LCD Projection for sale for $2699 CAN. This would be my first HDTV and so have a few concerns.
1. Is there or is there not PIP capabilities in this set? If none, then is there some form of split screen function where i can view two different channels on the same display?
2. I've read issues with lamps and expense. Does such a set last several years or is a dying lamp a common thing within a couple years?
3. People have mentioned standard definition display is crap on it. I'll be going out to check the set in person but can someone give me an idea of what bad means? How is it relative to a standard def TV set (NTSC analog signal)? Are we talking blocky and so unwatchable that it is difficult to read hand writing or make out character contours?
4. For the quality and size, is this the best HDTV 1080p display for my money or is there something smaller (47" to 60" is fine) of equal/better price? Im open to LCD, Plasma, or anything else that can be the best bang for my buck...
Thanks.
You need to evaluate with your own eyes. Main issues will be deinterlace quality, dark motion blocking and object edge performance in motion.
They will make excuses why they can't show you SD on it. Make your own 480i DVD including off air sports, dark movies, telecined film dramas, camcorder material, etc. Memorize the performance of these clips on your currrent TV and computer.
Take along a DVD player and component cable in your car in case they claim they can't play your DVD. It's important to hook up analog component 480i to test all the modes on the HDTV.
If you're going to be using S-Video or composite sources, test those inputs as well especially composite.
sony Vpro 10 "video longer than sound" sony hdr-cx116e, part II
By cesarin in forum EditingReplies: 16Last Post: 11th Oct 2011, 07:20 -
Primary Concerns About "Cheapo" Media?
By CobraPilot in forum MediaReplies: 14Last Post: 24th Apr 2010, 23:19 -
HD video from laptop to HDTV - "Clone" or "Single?
By mr-scarface in forum Software PlayingReplies: 1Last Post: 1st Jun 2009, 23:06 -
Help converting a "HDTV" non-DRM WMV to a PS3 friendly format
By FulciLives in forum Video ConversionReplies: 6Last Post: 17th Sep 2008, 22:39 -
Do hdtv owners use the "fill" mode to get rid of "underscan&
By yoda313 in forum PollsReplies: 20Last Post: 11th Jul 2008, 20:02
