Looking for something that has good quality for 480p. Can S-video record in 480p?
No. There is no 480p in standard definition broadcast video. The best you'll be able to do is capture 480i then inverse telecine or deinterlace.Originally Posted by Mysteriouskk
Would the Pyro AV Link be my best choice for the price range to capture xbox 360 footage at 480i?
Many ways to capture 480i. The Pyro would be a good choice but generates large files (DV format @ ~13GB/hr.)
If you have a DV or D8 camcorder you might be able to use it to record or "passthrough" to a firewire port. That would be similar to using the Pyro or an Canopus ADVC 100.
A $50 "raw" capture card can do as well but will require more CPU power and be more prone to dropped frames.
A hardware MPEG encoder like the Hauppauge WinTV PVR series will work if you don't plan on extensive filtering or editing. -
There is such a capture card that does this (have been looking for it for awhile... but no luck). It can capture: 480i/480p/1080i - It's the Earthsoft PV3 (no logner for sale from what I understand)
Looking at this capture card, it appears to only take video inputs through D-Terminals.Originally Posted by Seraphic-
At least, by the pictures supplied by that translated site.
Are there any devices that can capture 480p with component through USB or P
By Cyber Akuma in forum Capturing and VCRReplies: 7Last Post: 2nd Aug 2009, 03:29 -
Problem with 480p capture. Video seems squished...
By Mysteriouskk in forum Capturing and VCRReplies: 11Last Post: 9th Feb 2008, 02:24 -
WTB Video Capture Device, External, Firewire, $250 Budget
By bpatters69 in forum Capturing and VCRReplies: 3Last Post: 22nd Jan 2008, 20:08 -
Need USB/Firewire 480p capture over component
By Try4ce in forum Capturing and VCRReplies: 2Last Post: 3rd Jan 2008, 16:50 -
Capture HD from your game consoles for around $300 (480p/720i/p/1080i/p)
By Mysteriouskk in forum Capturing and VCRReplies: 4Last Post: 22nd Oct 2007, 20:00
