I have a couple AVI files that a friend of mine ripped from a DVD using mencoder. Aside from the various special features and little videos, the main files are both the same primary video, one with the normal audio and one with the commentary audio.
Well, no reason having the video twice, right? So can anyone point me in the right direction for converting these two AVI files into an MKV with two audio tracks? I'd prefer Mac and/or Linux tools (can mencoder do it?), but I can make use of a Windows machine if I have to. Thanks.
Regards,
David
"It's hard enough to live in a world where you grow old and die... why be disharmonious?"
-Jack Kerouac -
MKVToolnix (Linux, Windows, MacOS).
AVI-Mux GUI and VirtualDubMod (Windows).
From MEncoder docs:
14.1.11.3. Muxing into the Matroska container
The tools required to create Matroska files are collectively called mkvtoolnix, and are available for most Unix platforms as well as Windows. Because Matroska is an open standard you may find other tools that suit you better, but since mkvtoolnix is the most common, and is supported by the Matroska team itself, we will only cover its usage.
Awesome, thanks!
-Jack Kerouac
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
How to play MKV, MKV to AVI, MKV to DVD, MKV to Xbox 360 or Playstation 3
By Baldrick in forum Video ConversionReplies: 2Last Post: 8th Mar 2012, 03:45 -
Best way to batch convert xvid/avi files to mkv/x264 files?
By gaikokujinkyofusho in forum Video ConversionReplies: 1Last Post: 13th Jan 2012, 07:31 -
how to link togerther some .avi files to create a dvd
By marlo in forum MacReplies: 2Last Post: 10th Jul 2011, 06:12 -
How to Create FLV files from AVI material ( Xvid / Divx )?
By devilcoelhodog in forum Newbie / General discussionsReplies: 5Last Post: 19th Jan 2010, 10:31
