I need to add music to a video file using Vegas. I'm looking into importing the VOB directly into Vegas, but I don't think it's going to work. I've tried converting the VOB, but it always looks terrible. What would be the best way to get it into Vegas without losing much quality?
Conver to DV AVI:
1) If you don't have it already, download and install the free Panasonic DV Codec.
2) Get VirtualDubMod (also free). Open the desired VOB file in VirtualDubMod.
3) Click: Video -> Full Processing Mode
4) Click: Video -> Compression -> Panasonic DV Codec -> OK
5) Click: Streams -> Stream List -> Right click on audio -> Full Processing Mode.
6) Right click on audio (again) -> Compression -> No compression (PCM) -> OK
6a) Or, for no audio, select audio with single click -> Disable -> OK.
7) Click: File -> Save as -> [filename & location] -> Save
This will give you a DV AVI with WAV audio.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
Convert to DVD (VOB) Highest Quality converter?
By Mark97213 in forum Authoring (DVD)Replies: 12Last Post: 15th Feb 2011, 11:47 -
Convert .vob to another format with max quality
By alexv305 in forum DVD RippingReplies: 7Last Post: 19th Jun 2010, 23:36 -
Want to convert from VOB to .mov without losing quality
By kleiber in forum MacReplies: 5Last Post: 14th Feb 2009, 08:00 -
How Do I convert DVD Episodes in AVI in 350MB in highest quality posible
By Rockstar452 in forum DVD RippingReplies: 4Last Post: 29th Oct 2007, 04:39 -
Best way to convert avi to MPG DVD Compliant(highest quality)
By andre477 in forum Video ConversionReplies: 19Last Post: 25th May 2007, 05:59
