I am looking for some web-sites with as many info on LCD TV as this one has about players. Most of those I have found have very few models reviewed and are primarily commercial. Thanks.
Help![]()
I recommend http://www.avsforum.com/avs-vb/forumdisplay.php?f=166 ...no lists but you will get good recommendations.
Amazon.com is another good source. I have VERY mixed feelings about AVSforum and while it can be a good source of information, I'd advise that you first decide what you want and only THEN consult AVSforum. AVSforum can be very overwhelming. In my opinion it's too big and there's too much information there, so you're better off to decide what you think you want first and then look to see if the gurus there think the TV is OK.
If you want a personal recommendation, I bought the Samsung LNS4096D LCD HD TV late last year. It has cable card (look that up to see if you want it or not - it add to the cost of this model and I think the 4095D is the same TV minus cable card at a lower cost) and everybody who's seen it raves about it. Everything looks good on it, even VCD. Whatever TV you get, be sure to have the best quality connection between your components. This means you MUST use either DVI, HDMI or component between your cable box (this is why I have cable card - no cable box), your DVD player and anything else. Do note that S-Video is a low quality input and composite is just awful. People who bitch about how much things suck on their HD TVs usually are using low quality S-video or composite video inputs. Yes, they do suck. Finally, my very strong recommendation is that you change the display on the remote between 4:3 and 16:9 all the time depending on the source and you do NOT just leave the TV in 16:9 mode all the time because lower quality 4:3 sources such as VCD and standard definition TV look a lot worse when stretched to 16:9 and they are not too bad at all in 4:3 mode. -
And yet, many people here keep telling us how bad SD stuff looks on LCDs, and forget about it for good HD display. I can't comment on the latter, not having seen it, but I'm just not impressed with any plasma displays I've seen, regardless of what is being fed into it. (Recognizing that the setups may not be very good in most showrooms . . . . ) Personally, I have found the Sharp Aqous models to be acceptable for SD . . . but I'd still take a really good CRT over this any day, if one could still find them. This does leave me intending to investigate DLP, the next time I have to purchase a display.Originally Posted by jman98
All well and good, but there is likely to be a weak link somewhere in the chain. Those Polaroid 2001s (which have plenty of reported problems) were the only units I've heard of that had Component IN connections. S-Video is the best connection available, going into many video components, including all the better DVD recorders, while they were on the market. (I don't know about the cable or sat providers' DVRs, but I have no plans to use one.) Most of the decent gear around has at least Component Outs, though I wonder if something may already have been lost by that point.Originally Posted by jman98When in Las Vegas, don't miss the Pinball Hall of Fame Museum http://www.pinballmuseum.org/ -- with over 150 tables from 6+ decades of this quintessentially American art form.
what conversion programs do most web sites use
By Magpye in forum Video ConversionReplies: 6Last Post: 24th Aug 2011, 11:53 -
Can you recommend a good no sign up web site to send a large size video?
By coody in forum Video Streaming DownloadingReplies: 3Last Post: 6th May 2011, 01:06 -
Would you recommend a CRT or LCD to monitor VHS capture?
By DaveP56 in forum Capturing and VCRReplies: 2Last Post: 5th Feb 2011, 14:12 -
Removing a web sites name from clips
By prorodeolover in forum EditingReplies: 1Last Post: 14th May 2008, 00:36 -
ARE there web-sites that lease, and i join and use their software
By Lennoxtown in forum ComputerReplies: 1Last Post: 13th Aug 2007, 07:55
