Results 1 to 11 of 11
  1. anyone knows where to find this please
  2. Member bendixG15's Avatar
    Aug 2004
    Google it .. all kinds of hits
  3. well i did try google b4 coming here but cannot find a site to install this codec as when i try to use videolan to play this movie all i get is audio but no video just a grey screen
  4. ffdshow includes a CRAM decoder.
  5. well i have just installed ffdshow and hasnt made any difference where is this cram decoder on ffdshow then
  6. Start -> All Programs -> Ffdshow -> Video Decoder Configuration -> Codec -> MS Video 1 -> Libavcodec
    Also in the VFW decoder config.
  7. well just checked all of that and its same as you put here
    but I still cannot view video using VLC media player just get audio with just a grey screen no picture
  8. That seems to be a problem with VLC. I can play them in several other media players -- WMP, Mplayer2, MPC, KMPlayer. Windows ships with Microsoft Video 1 codecs.
  9. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    VLC uses its own (internal) codecs, and doesn't rely on the codecs (or DirectShow filters, etc.) installed on a system, so it won't be able to take advantage of ffdshow. As jagabo suggested, you can try one of the other players.
    Are you using the current version of VLC, by the way?
  10. I have latest version of VLC player too
    Dec 2004
    Australia
    Most of ffdshow's decoders come from libavcodec which VLC also uses, so it is a little odd. Still VLC always used to be behind in terms of syncing with ffmpeg. How does it play in mplayer or even ffplay?
