Hi! I transfered some VHS to DVD, they where in MONO audio, so I extracted the audio and made another DVD but the audio only comes out from the center speaker on my home theater. is there anyway i can re-encode that .WAV so that the audio comes out from all speakers? I have Adobe Audition 2.0.
thanks
If your home theater is set up with Dolby Pro Logic, mono audio will come out the center speaker. Put you amp in stereo mode and it should come out the left and right front channels.
Hi, weird thing is I have a different audio and it comes out from the right speaker only. Is there a way I can re-encode the files? not the home theater system?
I mean that i have 2 audios, one comes from the center speaker, the comes out from the right speaker, i wish to make em come out from all speakers or from right and left.
Okay, I can write a script for you to create 5.1. You need to post ten second clip of your source file - don't convert it or anything.
DVD-R sound coming through only one speaker
By Marshfish in forum Newbie / General discussionsReplies: 5Last Post: 7th Sep 2011, 02:40 -
How to restore audio on the right speaker on a video file
By Tintin11 in forum RestorationReplies: 8Last Post: 13th Nov 2010, 08:30 -
Edited sound jumps from speaker to speaker
By len hend in forum AudioReplies: 3Last Post: 23rd Jul 2010, 06:49 -
Audio out of only one speaker - ULead/EasyCap
By gmania in forum AudioReplies: 0Last Post: 16th Oct 2009, 22:03 -
stereo to 3.0 conversion? (to use the Center speaker as well)
By zee944 in forum AudioReplies: 3Last Post: 13th Oct 2007, 05:04
