Hey! I am a newbe in this and I have tried a lot of thing to burn a VCD and I still dont get it! Ok, first of all I have downloaded some MP3 from the web...then used VCD Easy to make the bin/cue files, after that I have burnt the .cue file using CDR Win ,finally I play it on my DVD player and all I get is the sound!!! What am I doing wrong? :oops:
Isnt an mp3 just sound ? Anyway, I am surprised that the DVD player could actually play the sound !
I'm a bit confused. It sounds to me like you aren't actually creating an SVCD...are you actually using video here? MP3 is only audio..and yes, I'm also quite impressed that your player will play it at all
Sr.Geroff:
Interesting way of attacking this one. First, I'd make sure the files you are working with are really VCD. Secondly, try another burning method other than VCDEasy. Might I suggest using the Nero VCD wizard or something to burn for you...
Hope this might help.
