I've got a rather unusual problem in VirtualDub (1.6.14) that started happening recently. I've edited many videos in it without problems, but all of a sudden run into the problem where if I edit any vido to cut out bits (e.g. commercials) and save the avi with "Direct Stream Copy" for both audio and video, the audio in the resulting video will drift out of sync as the movie plays.
All the settings in VirtualDub are at their defaults. I know I could play with frame rate adjustments to get the audio to sync, but for the test case described above, I shouldn't have to, as I'm not bringing in a new audio stream. I've tried with several avi files now, basically opening it in VirtualDub, cutting out just 3 minutes or so from the middle, setting both video and audio streams to "Direct Stream Copy" and saving a new avi. In all cases, the audio is well out of sync by the end of the avi.
In fact, if I load up any avi, set video to "full processing" and use a different codec and reencode a new avi, even that video will have audio drift. So it seems any kind of processing within VirtualDub screws it up.
I haven't knowingly installed any new audio or video drivers recently and as I mentioned, I've edited plenty of videos using that installation VirtualDub before. Can anyone think of a reason I'm getting these problems?
Thanks.
AVStoDVD audio out of sync from TS source
By nazopo in forum DVD RippingReplies: 3Last Post: 20th Dec 2010, 22:02 -
AVC: Unable to view the Video in sync with Audio
By bulava in forum Software PlayingReplies: 6Last Post: 19th Jun 2010, 22:15 -
Audio Source Missing from VirtualDub
By Flynn in forum Capturing and VCRReplies: 3Last Post: 5th Jun 2010, 05:58 -
VirtualDub: "The audio codec cannot compress the source to the desired
By user2008 in forum Capturing and VCRReplies: 6Last Post: 12th Jun 2009, 19:35 -
Virtualdub error with DV files - Audio Samples not found in source
By kbehel in forum Video ConversionReplies: 4Last Post: 30th Mar 2008, 03:40
