I have a Pioneer DVD-RW DVR-110D and used to be burning 8x disks that worked fine.
I bought some 1-16x disks from play (100 of them)
I then tried to burn using nero and dvd decryptor and it wont write above 4x!
I try selecting max speed or dvd decryptor and on nero it wont let me select any other speed
at the end of Pioneer DVD-RW DVR-110D it says 1.08 could that be a low version or something? sorry i;m newb hehe
What is the problem?
	Those are going to be one of these media id's - MXL RG04 (unlikely), RITEKF1 (very likely) or ProdiscF02 (likely). My guess is that newer firmware might help. Go here:Originally Posted by Lighters
 http://www.pioneer.eu/eur/content/support/support/software.html#fdvdwriter
 and scroll down to the link for 110D fw version 1.41 dated 5/26/06. If you already updated firmware then I'm not sure what to suggest that is easy. Good luck.
	i can now write at 12x but not 16? any ideas? i am sure my burner supports 16x and my media certainly doees
	Burning speed is controled by the firmware of the burner. If you have the latest firmware, then there is nothing further you can do except to get a different brand of media.
 Chances are, your burner doesn't perform well with that type/brand of media, and that is the reason for the firmware only setup to burn it as 12x. It's usually not the best idea to burn media at 16x anyway, especially when you aren't using quality media.Google is your Friend
	First of all. thanks for the help! - Appreciated!
 Why is it not a good idea to burn media at 16x btw?
 Does that means its not a good idea to burn media at 12x or is that a good idea?
 What are good brands for my pioneer 110d has anyone got one and could reccommend anything? :S
 tah
	You may want to use MCSE to see what media tables are in your firmware and the speeds which are supported for those media. MCSE is listed in the tools section on this site.
 The conventional wisdom on this site is to burn TY or Verbatim media, and many owners of japanese badged DVDwriters recommend burning at half the rated speed.
 If I could only burn reliably at half the rated speed, I'd throw my DVDwriter into the trash, and buy another. But that's just my opinion.
  Pioneer DVR-110D - Internal target failureBy tjax in forum DVD & Blu-ray RecordersReplies: 5Last Post: 27th Mar 2011, 18:41
  Firmware disk for Pioneer DVR-533HBy jjmdtw in forum DVD & Blu-ray RecordersReplies: 7Last Post: 24th Oct 2008, 06:31
  Hard Disk Replacement on Pioneer DVR-433HBy linkox in forum DVD & Blu-ray RecordersReplies: 4Last Post: 29th Jun 2008, 19:21
  Pioneer DVR-920HS ... help !! (Hard Disk)By indio76 in forum DVD & Blu-ray RecordersReplies: 8Last Post: 4th Feb 2008, 07:17
  Can anyone help on this one please - Pioneer 110DBy mattiusb in forum DVD & Blu-ray WritersReplies: 30Last Post: 3rd Jul 2007, 03:37
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
