Good afternoon friends,
I am having a problem that I haven't been able to google for 2 weeks now. It seemed pretty simple...but I am really tired of getting nowhere now.
I have a football match on my hard drive. It is a large VOB file of 4GB.
I know how to create DVD Video.
But I would really like to create a menu for that DVD, like an autorun menu, where I could select FIRST half, SECOND half and so on.
I don't even how to call this operation in English. Is it called authoring?
Can anybody reccomend an easy way, or an easy software?
Thanks a lot,
Mihnea
Tmpgenc DVD Author is a pretty good entry level authoring tool. Reasonably priced as well.
You could also look at GUIforDVDAuthor if you want something free.Read my blog here.
I'd try TMPGEnc DVD Author. It's easy enough to learn for beginners.
Here are a few guides that might get you started:
http://www.dvd-guides.com/guides.php?category=dvdauthor&name=tmpegencdvdauthor
https://www.videohelp.com/forum/viewtopic.php?t=224833
http://www.rita.lt/dap&js_guides/TMPGEnc_DVD_Author_ILLUSTRATED_GUIDE_by_dap&js.zip (A PDF file)
https://forum.videohelp.com/viewtopic.php?t=318702
http://www.doom9.org/index.html?/mpg/tmpg-dvdauthor.htm -
thanks for your answers. So Authoring is indeed the term I was looking for
Yes. from our GLOSSARY:
And the DVD structure: https://www.videohelp.com/dvd#structAuthor
To format video into a form ready to burn onto a recordable disc or to stream onto the Internet. VCD, SVCD and DVD Author is to format video into its standard file structure and also add optional menus, chapters, audio tracks, subtitles, slideshows and much more.
Guide for extracting menus for editing, and reinserting edited menus
By manono in forum Authoring (DVD)Replies: 167Last Post: 8th Dec 2022, 02:44 -
Better Menus
By clinging2thecross in forum Authoring (DVD)Replies: 3Last Post: 13th May 2011, 05:10 -
Menus folders or sub-menus
By GymDad in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 9th Nov 2008, 07:43 -
Help with menus
By miickEe in forum Authoring (DVD)Replies: 11Last Post: 5th Mar 2008, 20:45 -
Magix Movie Edit Pro Menus and Sub-menus
By gayclarke in forum Authoring (DVD)Replies: 8Last Post: 11th Aug 2007, 10:07
