How do I convert layered WMV files to another format?
When I open these files in Windows Media Player they are a couple hours long. When I open them in Quicktime using Flip4Mac, they are an hour long.
How do I convert these files to retain the length?
What do you mean by "layered"?
Do you mean files that are, in effect, playlists? (aggregates of segments)
Have you tried WME (using load, export to DV-AVI, then convert elsewhere to format of choice)?
Might be much more difficult if you're using a Mac, though...
Scott -
They may not be layered. But they are full length when played in Windows Media Player and half length in Quicktime. When exported in Quicktime, it only recognizes the half length.
What Mac utility is there to export the full-length video to a different format?
(WME is a Windows product and I am on a Mac, which is why I'm in the Mac forum.)
Should converting a mov file to wmv be so small?
By abrand88 in forum Newbie / General discussionsReplies: 2Last Post: 15th Apr 2010, 14:47 -
Converting .mov file to .wmv results in poor quality?
By zenfor in forum Video ConversionReplies: 2Last Post: 6th Feb 2009, 20:00 -
Banding when converting MOV to WMV
By whoisquilty in forum MacReplies: 2Last Post: 22nd Jul 2008, 11:35 -
converting .mov files to something I can use
By weazel_k in forum Authoring (DVD)Replies: 2Last Post: 1st Sep 2007, 17:46 -
newbie: converting wmv to mov, mpeg, etc. = loss of audio
By adambolo in forum ffmpegX general discussionReplies: 4Last Post: 17th May 2007, 11:27
