    Jan 2006
    is there a program
    convertxtodvd does this , but my video qualtiy isnt good with that program
    I need a program where I can make my apple movie trailer , into a dvd file and keep the 5.1 sound
    Apr 2004
    Miskatonic U
    In your other post you seemed to have come to the conclusion you are better off sticking with ConvertXtoDVD. That's fine, but if you choose to try an alternate route for encoding the video there is nothing stopping you using ConvertXtoDVD to convert the clips as well, then demuxing the AC3 audio out and using it elsewhere. Not the most efficient way, but it would work.
    Read my blog here.
