Hello All.
I have tried many times, but I am trying to find out what is the best conversion tool to use when converting from Avi to Mpg.
Thanks in advance.
ConvertXToDVD if you want a DVD and a all-in-one converter, otherwise to just a MPEG file, most any MPEG encoder. I use TMPGEnc most often. It's a little slow, but easy to set up. Or Procoder is faster and does well, or CCE, or..... https://www.videohelp.com/tools/sections/video-encoders-mpg-dvd
And you didn't state freeware or payware. Freeware: HC, or QuEnc, as mentioned.
I rarely use just one tool, though. I treat the audio and video differently, and it depends on what I need to fit the MPEG to and what the final format is to be. Could be DVD, SVCD, VCD or just MPEG.
stuck for a program to join mpg's without reencoding
By orbspider in forum EditingReplies: 12Last Post: 8th Dec 2011, 11:57 -
best program for separating one large MPG file to several sequential files
By nplovernmi in forum EditingReplies: 3Last Post: 20th Aug 2011, 18:09 -
MKV to AVI program, hardsubbing program, adding subtitle to DVD Flick
By projecttemp in forum Video ConversionReplies: 1Last Post: 21st Sep 2009, 09:42 -
Authoring program? (m2v's/ac3's/mpg'sVOB's)
By RobAdam in forum Newbie / General discussionsReplies: 1Last Post: 11th Nov 2007, 07:53 -
Tried every flv to mpg convertor program, no luck.
By ry94080 in forum Video ConversionReplies: 4Last Post: 16th Jun 2007, 01:01
