Im trying to convert an AVI file to a video_ts folder and have gone crazy with different settings. When searching the forum I've read a lot about making short clips to save time. I tried setting the "start from" time very low which i thought would mean a short clip - but the encoding time didnt chance. Then i tried a higher start time number to see if that means the end of the film - but still the encoding time is the same.
How can i make shorter clips to se the resulting video:ts folder without encoding the whole avi file?
Thanx
Try opening your AVI in ffmpegX, setting the "Start from" time, then use the Split button to make a two-part copy of your AVI; part 1 from 0:00:00 to the set time, part 2 from the set time to the end of your file. Next, open the small part 1 in ffmpegX and convert that.
Sync/align one short clip into one big clip
By diamondback in forum AudioReplies: 1Last Post: 2nd Nov 2011, 09:31 -
How do I make a short flight sim film/video?
By TerryW in forum Newbie / General discussionsReplies: 3Last Post: 12th Aug 2011, 15:04 -
How to make a short animated movie/video clip? Example included.
By UmmAddan in forum Newbie / General discussionsReplies: 1Last Post: 3rd Feb 2009, 09:36 -
Cutting a short clip from a DVD
By Nutmeg7 in forum MacReplies: 1Last Post: 13th Nov 2007, 22:58 -
Short video clip to stills
By swkenney in forum Video ConversionReplies: 2Last Post: 16th Sep 2007, 12:25
