    May 2007
    Hi, I'm trying to convert a Quicktime .mov to .flv with ffmpegX. The Quicktime was exported from Final Cut Pro with the default "Broadband-Medium" settings. The file stutters during playback, not like a low framerate stutter, but an irregullar stutter, like it loads a couple frames, shows them one after the other, and then pauses a bit before showing any other frames. I'm using the flv player at http://www.jeroenwijering.com/ , which is the one ffmpegX recommends, so I figure it should work, and I know it works with other flv files.
    Any clues about why this is happening? I think other user's have had similar problems. When I encode the flv, the only change to the default settings that I make is to check "Invert mapping" under Audio, since if I don't, it just makes a Zero KB file.
    Thanks for any tips you can give.
  2. I'm having the same problem. The quality of the movie appears to be good -- but it's that irregular stutter that makes it unbearable. Any and all help would be appreciated.
    --DrH
    Jul 2006
    I've used the standard export to Final Cut movie (in ver 4.5 it's called export to QuickTime movie) and imported it into ffmpegx, then exported a flash file and have had no problems. I also use Jeroen Wijering flash player
    G-4 Dual 1000
    Mac OS 10.3.9
    Final Cut ver 4.5
    Quicktime ver 6.5.2
