so i have an hdtv and have tons of avi movies. My xbox can finally play h.264 movies. my question is when encoded my avi movies should i set my output resolution/ratio to 1280x720 or should i keep using my standard 720x480 which i have been using for quite a while now.
any suggestions would greatly be appreciated.
Results 1 to 9 of 9
ok, so i've encoded the same file. one at 720x480 and the other at 1280x584 with h.264, and i don't see a noticeable difference in the quality of the videos. On my xbox it automatically resizes the video to fit the screen properly and there is little difference. the only difference is that one encoding takes an hour and the other took 3.5-4 hours.
just food for thought
What was the resolution of the source file?Originally Posted by greymammoth
Will the Xbox360 play the wmv-hd demo files? What do they look like?
http://www.microsoft.com/windows/windowsmedia/musicandvideo/hdvideo/hdvideo.aspx
hi ed,
the original source file was around 620x256. i'm also trying visualhub to see which one has better compression to quality rate.
regarding that link i don't think i can use that because i'm on a mac, though i would love to watch all my encoded movies with HD quality
that's what i figured afterwards. i'm fairly new to this, but i figure that would be the case. though i have not yet had the luck with dealing with a true HD file. i'm not sure if i ever will. Right now i'm just trying out various programs to see which ones have a better compression to speed rate, and so far visualhub seems nice.
Connecting PC To HDTV Newb Question
By pr0bation in forum Newbie / General discussionsReplies: 14Last Post: 14th Dec 2010, 18:29 -
Question about 720p HDTV networks
By jd594 in forum DVB / IPTVReplies: 3Last Post: 8th Sep 2010, 06:50 -
HDTV question
By snedeks937 in forum DVB / IPTVReplies: 1Last Post: 17th Jul 2010, 16:36 -
Question about using HDTV as Laptop Monitor
By Elemental Crisis in forum DVB / IPTVReplies: 2Last Post: 26th Dec 2008, 04:42 -
X264 HDTV question
By JConnor in forum Newbie / General discussionsReplies: 2Last Post: 29th Sep 2007, 15:44
